Question about Acer Aspire Computers & Internet
When I use my remote wireless I find I keep touching the touch pad
Can I swich off the touch pad as per other machines. If so how?
    Top Expert:
  • Acer Master
  • 23,128 Answers
You can disable it in control panel. Navigate to touch pad and mouse settings.
Posted on Nov 22, 2013
silveradoman
  • 58 Answers
SOURCE: replace wireless card on sony vaio vgn-n130g
usually there are screws coming upward from the bottom to remove the keyboard,then you have to remove the palmrest which the touchpad is integrated into.
Posted on Apr 19, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Touch Pad mouse not working
Connect and external mouse, then go to Toshiba website and download the touchpad driver for your laptop and reinstall them again.
Posted on Oct 10, 2008
leecom72
  • 4806 Answers
SOURCE: how to clean inspiron 1525 touch pad
Hi there.
The touchpad itself is easy to clean but if the liquid has got into the left and right click keys you may have a problem, a warm soapy partially dry cloth will take the residue off the touchpad but the soda may have got to the circuit board causing it to be slow to react.
To clean the left and right keys and under the touchpad you have to take the laptop apart, remove the keyboard and the front cover and clean under that where you can get under the left/right click keys and the ribbon cable of the touchpad.
This type of job is not for the novice and i would advise having a technician do it whether it's in or out off warranty, preferably Dell themselves.
Other than that the best option would be to buy a wireless or wired mini mouse which are much easier to use than the touchpad itself.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
Posted on May 20, 2009
geo_jonas
  • 555 Answers
SOURCE: Acer Aspire 6930 Touch pad not found
Please reinstall your Touch Pad Synaptics Pointing Device Driver then restart your machine.
Thanks
Posted on Aug 27, 2009
  • 15 Answers
SOURCE: HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Posted on Sep 04, 2009
F21
This error occurs if the touch-pad/LED assembly is not able to
transmit/receive data to/from the central control unit (CCU).
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Mar 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Can't right or left click on inspirion 1501, touchpad is fine.
It would appear that the left/right touch pad buttons have failed. You will have 3 options at this point in time.
1) Use an external wireless mouse such as a Logitech Wireless Mouse M505 for roughly $39.99
2) Use alternative features on the laptop. Left click is typically simulated by tapping or double tapping the touch pad itself and right click can be simulated, in most cases, by single tapping the icon and pressing the pop-up menu button, typically located between the right alt and ctrl buttons.
3) Search for a replacement component online and replace the component. Touch pad replacement will require you to remove all casing screws from the laptop and then remove the case. You will then expose the screws and cabling for the touch pad. I can not give more detailed instructions as this varies per laptop model.
Sep 21, 2011 | Dell Inspiron 1501 Notebook
F21 keeps on flashing???????????????????????????
This error occurs if the touch-pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the touch-pad/LED assembly and Central Control Unit (CCU).
Apr 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Saeco Talea. The drip tray will go up
Probably the touch pad is faulty. Before we decide that make sure the bottom touch area is dry and nothing sticking on to it.Can be check by removing the 2 screws underneath.
The worst case senerio will be the CPU which is not receiving the signal from the touch pad.
Jan 10, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Thanks
Aug 26, 2009 | Acer Aspire One PC Notebook
My touch pad remote is not programed
Hi, drop down panel door. enter installer code. you need to know what zone it was on before, because I recommend you try to delete it first. so next delete then sensor remote button til you get to right zone, then "done" then use add button sensor remote button then if its the small remotes 2 botton press the 2 bottons. for botton press top 2.sensor group 01
Jan 03, 2009 | GE Security Simon 3 Wireless Home Security...
Panasonic touchbook cf18
When I touch the touch pad my screen display goes off. it comes on sometimes by itself or when touch pad is touched. I have connected the toughbook to an external dispaly and can work no problems. help
Oct 22, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Touchpad
When the touch pad stops working it's one of three things. 1- A driver glitch, unistall the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. 2- The touch pad connector has worked loose. Take the palm rest with the touch pad off, disconnect the cable, clean the connectors, and reseat the cable firmly. 3- the touch pad has failed and will need to be replaced. The driver glitch is the most common, I believe that it should take care of the problem. Let me know.
Aug 06, 2008 | Dell Inspiron E1705 Notebook
Touchpad
This may be a simple driver glitch. Try uninstalling the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers. The touch pad either works or it doesn't, there's no in between, so if this doesn't work, then I'm afraid you'll have to replace the touch pad.
Jul 17, 2008 | Toshiba Satellite A205-S4617 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
