Question about Festina F16528/2 Sport Chrono Bike Watches
Festina 1/20 second hand does not reset to 0 - Festina F16528/2 Sport Chrono Bike Watches
3 Suggested Answers
SOURCE: Festina 16177 / 8- Tour de France 2005 - second hand not moving
The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
Posted on Aug 11, 2008
SOURCE: Bought F16223 Festina. Chronograph
Hi higloryngla,
I see that you need help with your Watch, you mentioned that the second hand is not moving at all when not in chrono mode.
I tried checking for an online manual but to no avail I have checked and only Found to have info on how to set the time and data but nothing explaining about your concern.
Instead I have checked Links that may be related to your concern if you would like to check them out they could be helpful to you.
Link - To set date and Time on the Festina Watch
Link2 - Links Related to Festina Watches
Festina - Links to where you can download the manual and the information about how your Chrono watch works.
I hope that this helps.
Thank you for choosing Fixya,
mvincentc
Posted on Jun 14, 2011
Why is my second hand not moving
THE watch is in stop watch mode (pause) , reset your side mounted post buttons to go to normal time
Sep 16, 2015 | Festina F16190/1 Chronograph Watch for Men
How to reset Festina back to zero
Pull out the crown, push the chronograph start button. You will see that the hand moves one second. once it is back to zero push back the crown. Depending on your model you might need to pull out the crown with one click for the chronograph timers and another click for the second hand.
Jul 01, 2014 | Festina Watches
I can't fix the date any more !
Hi, do you have the right instruction manual for this watch? If not, please let me know I will help you.
Festina Group Hungary
Mar 03, 2014 | Festina f16573/3
Festina chronometer. The hand that shows .01 secs does not return to 12 o'clock position. I would like to reset it if it is possible to do it using the buttons.
In chronograph mode but not running use the top left button 1 press at a time to advance the hand to the 12 o'clock position. Then return to normal moe - job done.
Jan 17, 2010 | Watches
How do I set the time and date?
Twist the crown until you can pull it back one notch. This will set the alarm by twisting in one direction. If you twist it in the other direction, you will set the date. Pull back one more notch and this will set the time. One you've done this, push and tighten the crown back in and press the bottom right hand button. The second hand should begin moving.
Dec 20, 2009 | Festina Chronograph 16162/1 watch
Large second hand not running, Stop Watch function?
Hey, it sounds like your watch is just fine! A nice watch to inherit.
The small second hand on the sub-dial is your normal second hand.
The large second hand is the second timer for your chronograph feature.
It should only move when you hit the side buttons. One of them (usually the top plunger/ button) will start the Chrono timer and then hitting it again will stop it. The bottom button should reset the hand to the 12 o'clock/ zero marker.
If the large hand is not functioning at all then there may be something wrong with the watch; perhaps the buttons are not making full contact within the watch or the hand may be stuck and need repair.
Hope this answers your questions. Post more questions if need be.
Congrats on your new watch.
Oct 21, 2009 | Festina Road Warrior F16273/4 Watch for...
Festina Dashboard watch - Adjusting the hand of the stopwatch
Your watch has quartz movement and stopwatch adjustment by one step (one full second) only. That means you will not be able to adjust stopwatch hand by using pushers on your watch as each push of the pusher will advance stopwatch hand for the full second, not the fifth or the tenth of the second, and the hand will stay slightly off anyway.
This happenened because the IC (integrated circuit) in your watch miscalculated the teeth count on chronograph wheel and stopped one or two teeth past or under the zero point. It doesn't happen very often, but in your case it did and the only solution is to find your nearest watch repair shop and ask for resetting stopwatch hand to zero.
This procedure needs partial disassembling of the watch and quite a great skill as the stopwatch hand must be removed and then refitted with great accuracy. All this needs to be done by very specialized tools as well.
I think this is the only solution of your problem unless you can live with that and just leave it as it is.
Do not forget to rate, please.
Feb 09, 2009 | Festina Dashboard 6719/3 Watch for Men
Jul 22, 2008 | Festina 16177 3 Watch
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Festina F16528/2 Sport Chrono Bike Watches Logo
Top Festina Watches Experts
Ansel Alberto
Ansel Alberto
240cpa
Are you a Festina Watch Expert? Answer questions, earn points and help others
