Question about Targus ACP50US Docking Station
Our company has multiple Targus Universal USB DV Docking Stations that suddenly stop working. This morning, 3 are not working. Any ideas on what the problem might be?
    Champion:
  • 221 Answers
What happens when they are plugged into a different laptop?
Posted on Dec 11, 2013
2 Suggested Answers
SOURCE: not working VGA function while using targus docking station
I had the same problem, but was able to just update the driver.
Go to Start --> My Computer --> Right Click --> Manage --> Device Manager --> You should see something with a USB and a question mark. Right click it and say update the driver. Then, it should, update the driver and you will get those unsuitable/not windows approved popups again. I just ignored them and went with it.
Note: I installed the Targus driver information from their website prior to doing the driver update (http://www.targus.com/us/product_details.asp?sku=ACP50US).
Hope that helps....Chris
Posted on Apr 30, 2009
Wifi on laptop stops working!
what laptop????????????????????????
If you don't have usb 3.0 you will have lots of problems. Also seems to want Ethernet connection not wifi.
Apr 08, 2014 | Targus USB 3.0 Video Docking Station...
Screens cut out, flash and then come back on frequently
It will be drivers. I had endless problems with a toshiba dynadock which took days trying to sort out. Once Toshiba released the windows 8.1 driver it worked a treat. You will need to use different drivers for each docking station.
Feb 20, 2014 | Targus (ACP60US) Docking Station
USB ports do not work with my XP Dell computer
Did you connect the power to the Port Replicator? The USB may be older in the Targus or the XP Dell. (1.1 older, vs 2.0 newer).
Sep 16, 2010 | Targus Port Replicator, Docking Station,...
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
Nov 07, 2009 | Dell 0Y3740 Keyboard
Not working VGA function while using targus docking station
Apr 17, 2009 | Targus ACP50US Docking Station
I have two docking stations for my Travelmate 8103WLMi both docking statins have lost there USB port connectivity. Is there anything that can be done so that the USB ports work again?
Try updating the drivers for the docking stations. Even in commonly used items such as docking stations which can be used without drivers, if you go to the manufacturer's web site and download drivers or management software, you will find it works better.
Otherwise, try somone else's laptop with those docking stations to make sure it's not your latop causing the problem. If it doesn't work for them either, the docking station is broken and there is really nothing you can do about that short of paying more than it's worth for someone to change out the USB component of the docking station.
Jul 09, 2008 | Acer Computers & Internet
Targus ACP50US Docking Station Logo
155 people viewed this question
Top Targus Computers & Internet Experts
J John
Laxman Bisht
Laxman Bisht
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
