Question about Hitachi 46BX01B 46" Rear Projection Television
Hitachi Ultavision 50 UX14B
When I turn the TV on the horizontal hold is not positioned correctly. Its not rolling but I get a half and half picture. If I try to adjust the horizontal hold button on the front of the set it has no affect
    Genius:
  • 1,153 Answers
Can you explain more detail?
Posted on Oct 09, 2007
SOURCE:
Horizontal lines
Contact the authorized service center for Hitachi. Never do any more adjustments. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 25, 2014 | Hitachi P50H401 50 in. Plasma HDTV
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
Blurry Picture
I know these models came out around 2001, and I'm afraid that the problem sounds like it is related to the bulb going bad.
This article outlines how many TVs from around the turn of the century have had similar problems to yours.
I know bulb replacement is an option. You may want to call around to TV repair shops and see what your options are. In the end, though, it may be time to start saving up for a new TV.
Jan 31, 2010 | Hitachi 43UWX10B 43" Rear Projection...
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
53 Hitachi Ultravison TV : Getting Horizontal lines rolling up
ok
this is called viedo noise
you will need to replace capisitor Cc10 its Value is 1000uf @ 16v the cap is a filter On Sw +9v Line , on pin 20 of Ic01, ( or corma Jungle IC)
Dec 30, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50UX10B rear projection TV
Good Day, eledttech;
Symptom: NO SYNC ON MAIN PICTURE PIP OK
Cause: IX04.
Good Luck, big IRISH.
Aug 18, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Tv roll
Are you sure the roll isnt Vertical? as if it is then all you need to do is adjust the VERTICAL HOLD PRESET POT which should be located on the PCB somewhere, its very unusual for TV.S to roll horizontally as then the picture just goes out of sync. and you would not see a picture at all. When you find the pot turn it ( with a small screw driver) slowly until the rolling stops, if it does not stop then you have a faulty component in the vert. sync. circuitry.
Feb 04, 2008 | Televison & Video
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Hitachi 46BX01B 46" Rear Projection Television Logo
110 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
