Question about Keurig Platinum B70 Coffee Maker
Keurig B60 screen flashes "Not Ready," "Auto Set Off" and "Brew Temp." The machine also will not shut off. Unplugging it does nothing, nor does the reset sequence of button pushing. Is there anything else I can try to fix my Keurig B60?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Lots of problems with the B60/65/70 units. There are some really good videos on you tube, but trust me, the process to fix is going to be a pain and cost ~$50. You should consider taking yours back for an exchange. There is a known problem with these models and it appears the retailers are being very generous on exchanges (check this out: http://babelniche.wordpress.com/2012/03/10/keurig-dumps-inventor-builds-millions-of-junk-coffee-makers/) .... Good luck
Posted on Jan 06, 2014
SOURCE: keurig B50
This didn't work for me, but I saw that it worked for someone on another forum, so here goes...
If you feel up to taking the bottom plate off your B50, take it off and look at the two connectors (blue & red wires) going to the green part in the center. The vibration of the B50 may have shaken them loose. Reseating the connectors may fix the problem.
Like I said, though, it didn't work for me. Still no love from the B50. It's just over 2 years old, though, so it's out of warranty. Maybe I'll see if I can weasel a B70 for Valentine's Day.
Posted on Feb 01, 2008
SOURCE: Keruig Coffee maker (B60)
Keurig alluded to the fact that it is the heating element that buring out and causing these problems.
Posted on Nov 01, 2008
SOURCE: My Keurig B60 will not brew.... it is like the
won't brew
Posted on Dec 16, 2009
SOURCE: My Keurig B60 does not run at all. The screen
Not sure if this will help, but I had the same problem over Xmas. This was posted 8 Jan, and I cut/pasted it here. Sounds complicated, but it's not. Just print it off instead of trying to remember it! I'd be interested to see if you had the same 'codes' as I, and if your machine had hot water when it ran... I have not done anything since that post...
Patient: Keurig B60
Symptom: "Not ready" light is on. Reservoir is filled and needles are clean, so problem is not user related.
Internet search yeilded some hope for another Keurig machine. While turned off, simultaneously press and release the small and med button, then menu three times. You get into a programming/diagostics menu. As you scroll (via the menu button) mine says Ready 602, Brew 265, Autooff 099, Set 007, Set/set 099, Descale 099, and Menu 000.
While at 000, press the med button but do not release. Press and release menu and immediately press small, then let go of small and med together. Pump runs and water is circulating, but is cold. Not sure if it should be cold (just a test routine, etc) or whether the heater is blown or something more troublesome.
Anyone have any ideas/experience with this information (I have no problem in ripping the machine apart if I have to. It can't be that complicated!).
Posted on Feb 03, 2010
kapishtech
  • 2272 Answers
SOURCE: Our Keurig B60 displays "NOT
Press the off/on switch and poof on the machine and then check. If that is not helping then try this procedure as follows:--- 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen .) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
--------- If this instructions also not helping then try this, instead of holding the medium cup while pushing and releasing menu .you simutaneously push and release medium cup and menu and then medium cup and small cup and then check out. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Aug 28, 2010
Turn clock off on keurig coffee maker
Don't use the clock or other features until you read the manual.
Dec 24, 2012 | Keurig B60 Coffee Maker
My keurig is flashing NOT READY and AUTO OFF SET and won't brew or even turn off
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 02, 2011 | Keurig B60 Coffee Maker
I do not know how to set the timer on the B60
OK - here you go:
1. Hit your menu button
2. The first prompt is to set the clock, if you do not need to reset your time - then just hit the menu button again.
3. Your next prompt is for auto off, this'll set it to cut off after a specified time. However, you also want it to come on at a specified time right?
4. Hit menu again. This takes you to auto on/auto off (a.k.a. your timer). From here simply use the buttons to the right or left of the menu button to set the time (watch out for am/pm).
5. Flip thru the last 2 menu options of brew temp & brew size. Make any changes you want to there.
6. Finally you'll end up back on the home screen - if you set the timer, then you will see "ONOFFTIMESET" on the home screen.
Jul 12, 2011 | Keurig B60 Coffee Maker
My Keurig B60 does not run at all. The screen comes on and says: Not Ready and also says auto off set. The cup lights do not flash. I cannot get the menu to come on. Unplugging it and plugging it in...
Patient: Keurig B60
Jan 31, 2010 | Keurig B60 Coffee Maker
The machine says REady To Brew- the lights flash and i press the button to brew. It says "brewing" but nothing ever comes out and then it goes back to "Ready to Brew".
Mine does this all the time. When it does, I tap the top of the machine and the coffee comes out. I don't know if it will work for you, but it works every time for me. It's like there's a small clog or something.
Nov 01, 2009 | Keurig Special Edition B60 Coffee Maker
B60 just flashes not ready yet ,have unpluged and tried that small cup med. cup and menu thing nothing changed
There has to be water in it first off. See my solution on the B50 with a similar problem. Before the lights blink ready the top (K-Cup Holder)has to opened and closed. Then the lights should blink and it should say ready to brew. I wish I had included that in the previous solution on the B50.
Feb 22, 2009 | Keurig B60 Coffee Maker
Oct 25, 2008 | Keurig B60 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
1,237 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
