Question about Home
Will not heat water
Water staying cold no more than 12 degrees
    New Friend:
  • 8 Answers
Is your water tank heating water?
Posted on Nov 28, 2013
Why the hot water temperature couldn't reach the set temperature (130 degree) in Amtrol WHS80Z indirect water heater?
I have a couple of thoughts. You may have air in the boiler water circuit at the loop that feeds the tank. You'll have to find the vent in the loop to get it out. Second, the automatic valve that opens for hot water may not be opening fully. Have you felt both the boiler water lines that go in and out of the tank? If the water going in is hot and the line out is very cold you have very little boiler water going through the loop. Make sure the isolation valves on the loop are open. Is your boiler full of water? If the boiler loop lines are hot going in and coming out, the tank is full of rust or debris and no water can get to the fins on the internal tubing to pick up heat. If that's the case there is no repair and its time to get a new tank. Hope this helps good luck.
Nov 04, 2014 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Electrolux ewx14440w washer dryer will not heat water
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
Oct 28, 2012 | Electrolux EW1000i Front Load Washer
Can it be put in a carport year round
Cold weather will not cause problem. The refrigerant stays at gaseous state well below freezing temperature. If i am not mistaken R134 boils at -27 degrees F. below that it would turn liquid but even then it still will not harm the system. Make sure there is no water in the line going to the ice maker and water dispenser because water can freeze and bust the water line.
Jul 18, 2010 | Frigidaire 12 cu. ft. / 340 liter Upright...
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
95 Jeep Wrangler YJ...No heat, temp at about
It should be 200 degrees. If your running cold the only thing that regulates temp is the thermostat. If it is indeed 150 degrees thats why you have no heat.
If you replaced the water pump and the radiator for this condition then it was a waste of money. If you had a water pump or radiator problem it would overheat.
The fact that your blowing cold air tells me the that you really are 150 degrees or the heater core is plugged.
Mar 10, 2010 | 1995 Jeep Wrangler
The water in our bosh S9F1B dishwasher does not heat up. The programme seems to work ok, just the pots are cold.
check the water coming into.the unit. must be acertain degrees. the heater will only heat up to a certain degrees .ex if you have cold water going to machine the heater may make it warm.
Feb 23, 2010 | Dishwashers
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Does not chill drinks
you wrote that the wine cooler "only cools to 12 degrees minimum" I don't understand the problem?
12 degrees is really cold, in fact its freezing.
Oct 29, 2008 | Sunpentown Platinum Trim Cabinet...
Ice maker on G E refrigator
If you have low water pressure to the ice maker it can cause the unit to stick. If the water fill is ok then the ice maker is going out or the freezer is not staying cold enough. Icemaker has to reach about 12 degrees to cycle.
Apr 24, 2008 | Refrigerators
Home Logo
27 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
