I have 2 geovision GV 800 and 36 Cam. I want to install it together in 1 PC. Each card provide 16 slot for 16 cam so total is 36 slot. As u can see the motherboard i use have 2 PCI slot. Its an Intel board. So, can i know is it possible for me 2 plug in the 2 GV 800 card and run the 36 cam together with 1 PC.
yes you can, but recording will depend on size of hard drive. i work in the trade and you will require at least a terra bit to run 32 cams for any given period
I'm losing video and all the cams are in the same row. GV-800 it is a new system and the cams were...
(More)
I'm losing video and all the cams are in the same row. GV-800 it is a new system and the cams were already in place from another system and working fine. the cameras also are recording when nothing is there(motion sensing) 1 camera has lost its real time video, it will show but it skips while the others show in real time.
I have Geo Vision GV800 with 9 cameras running, i try to add more but cannot figure out how to get...
(More)
I have Geo Vision GV800 with 9 cameras running, i try to add more but cannot figure out how to get them to show up on my monitor when i click anything past nine it does not show
Hi we are using a GV800 card and GV software version 8.3 Recently we have replaced the exisitng...
(More)
Hi we are using a GV800 card and GV software version 8.3 Recently we have replaced the exisitng cameras and also connection wirings. Now we are able to see the video but we are unable to hear any sound. When we check this under audio setup a very loud noise sound is received instead of actual voice. The cameras we use have a direct port for power supply, one seperate port for video and one seperate port for audio. it seems there is ome problem with the wires/sockets. Please advice how can we correct the wiring
I have a GV800 with 16 inputs, and I want to add 2 more cameras, there is a option on the menu for...
(More)
I have a GV800 with 16 inputs, and I want to add 2 more cameras, there is a option on the menu for adding cameras but it onli gives me the option on the original 11
