Question about Konica Minolta DiALTA Di183F Copier
Di470 code c13f7 - Konica Minolta DiALTA Di183F Copier
C-13F7 code hai
Posted on Nov 02, 2014
Photocopy di470
The second or third draw is the duplexer if there is one its the draw that has no paper storage.
Apr 20, 2014 | Minolta Office Equipment & Supplies
Di 450
replace the print head, print head houses the LASER for the machine, might try this site as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 02, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta Di 450 code 13 & 14
need additional numbers codes are c-xxxxx
Mar 03, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta Di470 Error code C-0F24
COF24 is an AIDC or Automatic Image Density Control failure code. It means that the machine can not properly detect the developer to toner mixture or ratio in the process/developer unit. This can be caused by an AIDC sensor failure, Developer Drive problem or for some reason the machine is not getting toner as it should. Has the machine been running low on toner?
Before calling for service I would try resetting the code by opening then closing the front door(s). Do this a few times and see if the code will go away. If not then you will need a service person to diagnose and repair which part is defective.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Office Equipment & Supplies
Jose ask: minolta di470 keep jamming after registration, thank
Might want to check the Drum section and or transfer and separation assy.
Dec 21, 2009 | Minolta Office Equipment & Supplies
Konica Minolta DiALTA Di183F Copier Logo
121 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
