Question about Konica Minolta Laser, Toner, BizHub Pro c5501, c6501 - Cyan - 25,000 Page YieldCyan - 25,000 Page Yield
Konica minolta c6501 error code c-2414 - Konica Minolta Laser, Toner, BizHub Pro c5501, c6501 - Cyan - 25,000 Page YieldCyan - 25,000 Page Yield
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
firecontrol7
  • 6161 Answers
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Posted on Jul 31, 2009
SOURCE: IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Posted on Aug 23, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
Please let me know if one of the members can help me to obtain a DIAGRAM TO REPAIR A KONICA MINOLTA C6500 POWER SUPPLY UNIT MODEL NO. LVR-CE 29818 PART NO. A03UM402-01
Even KMBS Tech do not have schematics of that detail on circuit boards
The first code you had was dealing with the middle section of the machine which transports the paper from the right to the left, there is a circuit board that controls the section located under the front cover of that section. the next code you have deals with the scanner under the big glass. either home position sensor is dirty or bad or the drive motor for the scanner is bad or the drive motor board is bad.
Circuit boards about 1000.00 each.
Oct 14, 2015 | Konica Minolta Office Equipment & Supplies
C-3102
Fusing release code drive motor for fuser or home release sensor not working . Have a tech look at this before resetting
Jun 06, 2014 | Konica Minolta C6500 C5500 C6501 C6000...
Konica minolta bizhub pro c6501 error c2304
Printer control board (PRCB)
Developing fan/1 (M45)
Developing fan/2 (M46)
Developing fan/3 (M64)
Check the above fans or its the board that controls them $$$$$$$$$$$
Apr 04, 2014 | Konica Minolta bizhub Office Equipment &...
Error code c-2454
check the black developer motor and developer unit
Dec 21, 2013 | Konica Minolta C6500 C5500 C6501 C6000...
Konica minolta bizhub pro c6501 'no toner' message
What u mean by no toner message? If it says replace toner soon u need to new toner
Nov 22, 2013 | Konica Minolta Bizhub Pro C6501 Toner...
Error C-2801 with Konica Minolta C6501 C-2801 Gamma correction /Y aborted. Patch output voltage is low. (Error 1) Main body stops immediately and main relay (RY1) is turned OFF. Printer control board...
Remove the transfer belt unit and then remove the transfer belt. Verify all first image transfer rollers (p/n A03U 5012 00)are properly seated in their respective holders.
Mar 10, 2011 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhup 6501 error c-2452
Something with your developer causing not enough toner. Maybe an auger issue in the developer or in the toner feed itself?
May 19, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Laser, Toner, BizHub Pro c5501, c6501 - Cyan - 25,000 Page YieldCyan - 25,000 Page Yield Logo
210 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
