Question about Home Fencing
2008 gmc w4500
Drain plug size
4 Suggested Answers
  • 91 Answers
SOURCE: how to remove the rear drum off a GMC W4500
This is a full floating axle. The drum and the hub come off together. The axle must be pulled by removing the bolts or nuts on the hub center.Then the large nuts behind it must be removed. Now the hub and drum assembly can be removed. If you've already done that and the drum still won't come off back off the brake adjuster as far as possible. A ridge of rust sometimes forms inside the lip of the drum that will keep it from sliding off until the shoes are backed off. Very worn shoes can also literally wear grooves into the drum and make it impossible to remove until the adjusters are backed all the way off. If everything is rusted solid and you can't get anything to move check with the owner and, if it's O.K. with him, take the sawsall or the torch and cut the lower part of the backing plate out of your way. Then cut the adjuster in half. Now the drum will come off.
Posted on Mar 20, 2010
rabbit7954
  • 417 Answers
SOURCE: I have a GMC Sierra 2008 and I can't find the oil ...
The oil plug will be located on your oil pan. If you checked ther are you sure you checked all areas? I have never seen one anywhere else. Especially on an american made vehicle. I don't know your experience level but the oil pan is located just in front of the transmission under the engine. I hope that helps you find it.
Posted on Jul 05, 2010
  • 4349 Answers
SOURCE: 2008 GMC acadia has water leaking from sunroof , how do i fin the drain hose?
The drain hoses typically run from the 4 corners of the pan around the sunroof. Usually the blockage is from the top side, so open the sunroof and clean from there. Some applications require that you drop the ceiling material for access.
Posted on Mar 07, 2013
Transmission fluid capacity
It is a must that you use a silicone-based fluid such as Isuzu SCS Automatic Transmission Fluid -- Isuzu part # 2-90531-200-0
Check with dipstick with engine idle to see when it is full
Nov 13, 2017 | GMC Cars & Trucks
Where is the port to charge the A/C on the 2005 GMC W4500?
Hi, can i suggest you let a garage recharge your vehicle, freon can be hazardous to your health.
Jun 17, 2015 | GMC Cars & Trucks
Gmc w4500. 5.2 l turbo diesel. Hard to start
Glow plugs. does it smoke a lot after starting. Can you plug yours up at night
Jan 02, 2015 | GMC Cars & Trucks
Why is my 2008 gmc acadia front passager floorboard is wet
Floorboard is wet because the drain from the A/C Evaporator is plugged up with "gunk" Need to find the drain and clean it out.
For a 2008 the Battery has used up it's 60 month life and you need a new one
Mar 29, 2014 | 2008 GMC Acadia
NEED TO REMOVE THE TONE RING ON A ROTOR FOR A 2000 GMC W4500
it is a kept rotor... you have to press/pry/pull off the abs ring to access the many many torqx bolts that hold the rotor in place, these other answers are all wrong
Oct 10, 2013 | GMC W3500 Cars & Trucks
What is the warning light on a 2006 gmc w4500 it is red looks like a drop going into water
that would most likly be a coolant level sensor that u are seeing lok for your coolant jug an see if it has a sensor on it if so un plug it go start truck if the light dosent go off an no new ones come on there your answer if you repare your self just unhook batt. wait 5 minues reconect lights should go out on dash goodluck
Dec 16, 2010 | GMC Sierra 3500HD Cars & Trucks
Gmc w4500 with 5.2 L after driving loses throttle response and kicks code p1094 fuel rail pressure low at idle or deceleration
Follow this link. Hope it helps. Good Luck.
http://www.duramaxforum.com/forum/04-5-05-lly-duramax-powertrain/106-trouble-codes.html
Sep 28, 2010 | GMC W3500 Cars & Trucks
Where is the flasher relay on a GMC W4500. It's basically an isuzu.... Someone please help!!!!
if your turn signals are not working it may be the flasher unit is faulty,it is under the dash on the drivers side,it could be a cylinder or a square unit about 2" long with a connector plug on the top.....hope this helps.....cheers
Aug 10, 2010 | GMC W3500 Cars & Trucks
I have a gmc Sierra 2008 and I can't find the oil drain plug to change my oil where is it?
May 20, 2010 | 2008 GMC Sierra 1500 2WD
Home Fencing Logo
78 people viewed this question
Top Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Home Fencing Expert? Answer questions, earn points and help others
