Question about Badger 1 All Insinkerator 76039h 1/3 Hp Feed Garbage Disposal Black Opened
Insinkerator disposal motor hums but blades won't turn
The blades rotate easily, but won't grind when turned on. The blades only move when tapped with a knife handle on the center nut. How can I fix this?
    Top Expert:
  • Badger Master
  • 34,170 Answers
Probable replacement
Posted on Nov 22, 2013
When turning on garbage disposal power turns on but does not spin
Is the motor rotating, and cutter disc stationary?
If the motor is running but cutter disc is not moving, then disposal is probably broken and needs replacement.
If the motor is not rotating, and is making humming sound, then do not keep power turned ON or motor will burn out.
Then use allan wrench on bottom of disposal to rotate the motor until disc rotates freely. Also use wood broomstick handle down into disposal and wedge against side of sink opening to free cutter disc.
Also view ez disposal replacement steps:
http://www1.fixya.com/support/r7929008-replace_garbage_disposal
Oct 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1/2 HP garbage disposal not working. Motor hums, blades are not rotating. I can rotate the service wrench with tension.
I would keep working the impeller back and forth with wrench while running hot water thru disposal until it turns freely. You can see if there are any small bone fragments or other debris in grinding chamber and removing with long needle nose pliers. Good luck. Thank you.
Apr 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Blades will not turn. They turn with broomhandle but when I throw the switch, just get humming.
Whenever the motor hums without spinning, it is overheating.
Your motor has no obstruction since blades rotate freely, so motor lost power in the start winding.
Once motors overheat, and stop turning, then they are bad.
There are no replacement parts for disposals.
I wrote EZ disposal replacement step that will save time and sometimes money:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 22, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The motor tries to start with a low hum, but it will not power up. The blades turn easily and the reset button is not out.
If blades rotate freely, then there is no stoppage.
If motor hums, then circuit and switch are good.
If motor will not start, and reset is not tripped, then disposal has gone bad.
Motors slow down and overheat, and then they stop working.
Each time you hear motor humming instead of rotating, the motor is overheating.
All motors stop working some time.
There are no repair parts for disposals.
Drain is not clogged, so sink is usable until disposal is replaced.
I wrote EZ disposal-replacement steps from years when I worked apartment maintenance.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on disposal or any do-it-yourself project.
Feb 13, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage dispoal not working. The blades spin freely inside, the reset button has been reset, when you switch it on the moter makes a faint humming sound, and the allen wrench will not rotate either way.
You need a new disposal.
Free-rotating blades show there is no obstruction.
Humming says you have power.
Frozen allen wrench says bearings are rusted.
Motor is now overheating each timer electricity is turned on, and motor will overheat and stop humming.
At least the drain is clean and water is not flooding under the sink, which means you can continue using sink until disposal is replaced.
I wrote tips for installing disposal from days when I worked apartment maintenance:
Feb 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1 1/3 insinkerator not grinding
Hi, Sounds like motor went bad..
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sinkerator will only "hum" and not run to grind food
On The bottom of the unit there should be a place to put an allen wrench. Unplug unit, Insert wrench and turn the wrench back and forth this moves the blades if the blades move freely then nothing is stuck. If wrench does not move freely, with flash light inspect inside of disposal (the rubber flaps are usually removable to gain better eye site) if objects (bones, utensil, etc) are noticed remove them and try the wrench again if now freed problem solved. If wrench turned freely from the beginning and motor still hums. Replace disposal.
I hope this has answered your question, please rate how helpful the answer was. Good Luck and Have a great day.
Apr 03, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
MY BADGER 5 HAS POWER TO IT AND ATEMPTS TO TURN BUT WON'T, WHEN YOU TURN IT MANNUALY IT SEEMS GUMMED UP HARD TO TURN,AL OF THE BLADES ARE FREE AND NOTHING IS IN IT
Be aware that the wheel that makes up the entire floor of the grinding chamber is the part that rotates. There are two lugs mounted on this wheel that rotate freely, but they are not driven by the motor. There's a hole in the bottom middle of the disposer where you can insert an allen wrench (there may be a special disposer tool already in the cabinet) and turn the motor manually. If the motor does turn freely, but the disposer still hums and doesn't stat, that'll mean there's a problem with the motor's starter circuit. You or a motor repair shop could open up the motor and check the resistance of the windings, the centrifugal starter switch, etc., but your best value at this point, especially with an entry level model such as a badger 5, is to replace the disposer. If you get another one made by insinkerator you can install the new one in like three steps.
Dec 21, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator
The capacitor is probably bad, that's what makes it start to rotate. It's under the metal case on the side of the motor. Pull it off and take it to a motor to to replace.
Jul 23, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The blades on my Badger 1 insinkerator don't move. The motor hums when turned on. The reset button stays out when pushed.
You will need to free the blades by inserting the food disposal hex key or a 1/4 Allen Wrench into the very bottom of the disposal in the center. After inserting the wrench you need to turn it all the way in both directions to free what has the blades held up. It may be hard to turn but afterwards pull the debris out from inside the disposal. Hit the reset button and it will work. Do not keep turning it on until you free the blade and then reset.
Jun 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1 All Insinkerator 76039h 1/3 Hp Feed Garbage Disposal Black Opened Logo
187 people viewed this question
Top Badger Home Experts
Donni Steen
Tom Chichester
Are you a Badger Home Expert? Answer questions, earn points and help others
