Question about Belling Ovens
Oven not working
Get a flame but won't light up for heat
  • Belling Master
  • 5,323 Answers
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Posted on May 03, 2015
4 Suggested Answers
  • 116 Answers
SOURCE: frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Posted on Nov 22, 2008
SOURCE: Cannon Cambridge Double Oven. Main oven not heating up
Problem solved, Turned out to be the flame fail device. Next problem was sourcing part. Turns out that allegedly Cannon is now owned by Hotpoint so sourced part through them
Posted on Nov 26, 2009
dmftrucker
  • 1922 Answers
SOURCE: GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Posted on Nov 25, 2012
Not heating
My oven lights but takes ages to cook food. Also flame goes off if oven door is closed at the beginning of lighting the oven
Dec 16, 2013 | GE JTP45 Electric Double Oven
Burners work fine, pilot light in oven is on, but oven won't ignite
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Aug 28, 2011 | Ovens
Kenmorw built-in oven (Model #30129) won't maintain cooking temp, flame is off and on continously, take twice as long to bake or broil food. If the temp is set for 500, the oven temp might be 250.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 06, 2011 | Ovens
Hello, the top burners works but the oven does not light up. Only the red light in the bottom is on but it's not flaming. I've tried turning it off and on again but the flame still doesn't light...
heatman101
Nov 10, 2010 | Ovens
It won't heat up... even though there is a flame
Check The Power Source
If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
Check the Heat Source
When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
Feb 05, 2010 | Ovens
Nov 24, 2009 | Ovens
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
Jun 27, 2009 | Ovens
Bakers pride pizza oven
does it light then immediately go out? if yes, usually you have to hold in a button to allow gas to flow while you light the pilot, and hold this button until the therm0-couple is heated with the pilot flame. If the thermo-couple is not sufficiently heated and you let go of this button, the pilot light will go out as the safety circuit thinks there's no flame and unburned gas is entering the oven.
The other thing you could do is adjust the height of the pilot flame... there's usually an adjustment screw near the button described above which will allow you to adjust the height of the flame. Make the flame just big enough to guarantee that it keeps the thermo-couple hot AND that it can light the oven without being blown out.
Good luck.
Apr 21, 2008 | Ovens
Ovens Logo
67 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
