Question about Beko WME7247W Washing Machine
BEKO WME7247W door clicks shut then nothing happens. Have cleaned all filters. Water pressure is good.
At one point the rinse symbol started flashing, but it hasn't done that again. I think this relates to water. But we have taken off hose, checked filters, there is no issue with water coming in or out of machine. Help!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 125 Answers
Have you tried unplugging it and plugging it in again?
Posted on Nov 22, 2013
4 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: my beko wm5140w washing machine wont start cycle but lights are still on
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Posted on Dec 20, 2011
vladmototole
  • 226 Answers
SOURCE: beko washing machine WME 7267 fills with water but will not continue through the cycle
See if the filter is clean or if the exhaust hose isn't blocked.
Posted on Feb 23, 2012
kevin_getz
  • 1031 Answers
SOURCE: beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
Posted on May 22, 2012
Beko washing machine wme7247w showing E08
Beko Washing machine? What is that a French Model? LOL
Your water inlet valves (hot/cold) are bad and need replacing.
Jan 19, 2014 | Beko WME7247W Washing Machine
Washing machine does not rinse
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Mar 07, 2013 | Washing Machines
Wont fill with water
Jan 24, 2013 | Beko Washing Machines
ARFX125 h20 symbol flashing
Jan 21, 2013 | Washing Machines
Water wont empty from my machine
Hi if your beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Nov 04, 2012 | Beko WME7247W Washing Machine
My beko wma620a wont start the ready light is on but nothing happening?
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the dry spin with the drain valve/pump activatedso as to drain off all the water from the clothes during the spin.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 05, 2012 | Beko Washing Machines
Eo5 beko wme8227b
Hi if your beko wme8227b washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jul 04, 2012 | Whirlpool Washing Machines
My beko wm5140w washing machine wont start cycle but lights are still on
Hi if your beko wm5140w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Dec 20, 2011 | Beko WM5140W
The brand new washing machine beko 7247 is not going through the whole wash cycle, it is stopping when it gets to rinse. the rinse sign is flashing on the display, there is nothing wrong with the water...
Hi and welcome to FixYa, I am Kelly.
Since this is a NEW washing machine there is little you can do as a consumer that would not void your warranty. Check and make sure the drain hose is no folded or kinked. The locate your filter assy:
http://www.buyspares.co.uk/washing-machine/wme7247w-7143081500/pump-filter-assy/product.pl?pid=1905802&path=445291,110919&model_ref=583085
(inside the machine)
and make sure it is clean.
http://www.beko.co.uk/manuals/wme7247.pdf
See page 27 of this manual for directions on how to access and clean your pump filter.
If after performing this task and testing, if it still does the same thing, your are pretty much stuck with going through the warranty process. The warranty information is on pages 35 and 36 of the pdf link above.
Kelly
Apr 13, 2011 | Washing Machines
Beko WME7247W Washing Machine Logo
100 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
