Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Need to know how to reset password so neighbors can"t access my internet
Reset router password so others except chris cannot receive internet from my wireless router
  • 4 Answers
You might want to do a hard reset then do all the settings from scratch so you can set a system pass and a wifi pass for the network. use the 128 bit WEP setting.
Posted on May 07, 2009
    President:
  • 1,383 Answers
Http://192.168.15.1
this is defaults link for acces belkin router
then go to wi fi security then u see encrption security then u can reset pasword easily.
How can I remove my neighbor from my network
Easiest thing to do, Change the password to your router. Once this is done, it will prevent your neighbor from any further access to your router and of course prevent internet access. Most all routers are simply a local web address for access. Example: 192.168.1.1 typed inside a browser address pane will take you inside the router. Check your router for setup procedures.
Have a great night..
Sep 09, 2014 | Linksys By Cisco E2500 DualBand WirelessN...
Tip
Guide to Reset Password on a Cisco Router
How do I reset the password on my Cisco router?<br />I bought a Cisco 1700 router from an auction, but there is a password. How can I reset the router to original factory specifications? <br /><br />Sky sagem wireless router reset password? I just got this sky wireless router second hand and it has a password set on it. i tried to press the reset button at the back but it does not do any thing, it still comes as a password is set.<br /><br />How to reset password on dlink wireless router? I have a dlink wireless router model number DIR 825 . It works good but I am trying to access internet on my ipod and the password i have set is incorrect , this also happened when i tried to access internet on my laptop. When i first set up my ps3 i dont recall having to put a password in but this was when i first got the router. How do i reset the router password or find out what the password is AND if i reset the password or reset my router will my ps3 have to be reconnected or will it stay?<br /><br />How to reset password on a router? I recently acquired a linksys router (used) and need to know how to reset the password so that I can use it. Also, is there any way to modify a router to be useful as a cell/wifi blocker, or as a signal booster?<br />... <br /> ----From Yahoo Answers<br /><br /><br />To reset password on a Cisco/D-link/Linksys/Netgear router is a very common problem among people who want a secure network environment for surfing on the internet. If you are confused with the complicated procedure to reset or change the password on a router, or if you are trying to configure a Cisco router, but a password is blocking you from enable mode, don't worry, just do the steps as follows, password reset on a router is no longer upset to everyone.<br /><br />First, be informed that what you need:<br />.<a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router</a><br />.Computer<br />.Internet Connection<br />.Blue Serial Cable<br /><br />Guide for You to Reset Password on a Cisco Router:<br />1. Download a program called Putty from the first resource site below. PuTTy is a terminal emulator application which can act as a client for the SSH, Telnet, rlogin, and raw TCP computing protocols (PuTTy on Wikipedia).http://en.wikipedia.org/wiki/PuTTY<br /><br />2. Connect one end of the blue serial cable to the Cisco Router and the other to your computer. Open up the Putty program on your computer and select the radio button next to "serial" on the right-hand side of the start window. Click on the "Open" button in the bottom right-hand corner of the Putty start window to open the terminal.<br /><br />3. Power the Cisco Router on. As soon as the router begins loading in the green and black Putty terminal window, press the "Ctrl" and "Break" keys simultaneously until its going into rommon mode.<br /><br /><br />4. Once in rommon mode, you have to change the configuration register number to make the router boot from a blank configuration file. For the 2800 series Cisco Routers, the command "confreq 0x2142", changing the register number to 2142, worked. Search on cisco.com for information on your particular <a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router Series</a>.<br /><br />5. Type the restart command in rommon mode, which is "reset". This will boot the router up again. When it is finished, you should be able to type "en" to get into enable mode without a password.<br /><br />6. Once you change the running-config in RAM and save it to the startup-config in NVRAM, remember to change the configuration register number back to its default (usually 0x2102). This is important if you change anything on the running-config. <br /><br />Easy five steps help you finish resetting password on a Cisco router. Easy instruction, easy to follow. <br /><br />
on Jul 19, 2011 | Computers & Internet
Tip
How to configure router. How to access router configuration
When you buy a router they usually come with "setup" Cd's that set up your router, or guide you through the process. What most people do not know is you do not need this CD and in my experience these disc can cause frustration and confusion. <br /><br />You can access your router and configure it simply by using your internet browser like Internet Explorer or FireFox.<br /><br />On most routers(reference your user manual) you can access the router configuration page by going to the gateway address. The gateway address is the IP address assigned to your router. In a lot of the cases, this address is 192.168.1.1 but depends on your router. <br /> There are a couple of ways to find out this IP address. <br /> -Reference your router manual<br />or<br /> -In <a href="/../support/r9359087-find_wep_key_router_router_security#"><span>Microsoft</span><span> </span><span>Windows</span></a>, go to Start &gt; Run and in the run box type "cmd" or "command". A black window should open(MS-DOS). In this window, type "ipconfig /all". Look near the top of the output that is shows and you should see a "gateway address" field. This number is the ip address of your router. <br /><br />Once you know your gateway address, open up your internet browser as if you were going to go to a website. In the <a href="/../support/r9359087-find_wep_key_router_router_security#"><span>URL</span></a>(address) bar, type the gateway address and hit enter(see image below). A log in box should now show.<span> Again, reference your router manual if you do not know the administrative password</span>. Enter in your password and username. The following website has a list of default username and passwords and you may be able to find your router in the list. Click <a href="http://www.anameless.com/blog/default-passwords.html">here </a>for the website. <br /><br /><img src="g33k4u_7.png" /><br /><br /><br />Once you log in you now have access to the router settings and you can configure what you please. You can configure wireless settings, router log in credentials and other options. Have a look around and get familiar with it.<br /><br /><span style="font-style: italic;"><span style="font-weight: bold;">I would recommend</span> that if your router has a default password for </span><span style="font-style: italic;">admin/configuration</span><span style="font-style: italic;"> access, that you go ahead and create a new one. The default router passwords are usually very simple and this information can be easily found on the internet by anyone(as seen by the link I provided above!). People who set up home networks tend to leave this as is and it is a security risk. </span><br /><br /><br /><span>TIPS</span><br />-If you can't connect to the router and you know the gateway address, try plugging the <a href="/../support/r9359087-find_wep_key_router_router_security#"><span>computer</span></a> into the router directly using a Ethernet cable(LAN/patch cable). If you are still having trouble, you can perform a power cycle. Turn off your modem, router and computer. After 10 seconds turn on your modem, after 30 seconds turn on your router and after another 30 seconds turn on your computer. Try to access the router now. This also helps resolve other quirky router issues.<br /> -Make sure all the network cables, phone lines(if using DSL) and coaxial cables(cable/Broadband) are plugged in and secured firmly. <br /><br />-If you set up a password and username for your routers administrative access and can't remember it, you can reset the username and password back to factory default by performing a factory reset. On most routers this can be achieved by pressing and holding the small reset button on the back of the router for 15 seconds. <span style="font-style: italic;">Please reference router user manual for more information.</span><br /><br />I hope this article was informative. Be sure to check out my other tips and tricks. You can view my profile by clicking <a href="http://www.fixya.com/users/g33k4u">here</a>, and if you click Tips near the top left, you can view my tips!<br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /><span style="font-weight: bold;">How to configure router, how to access router, how to log in to router, how to configure router security, how to access router configuration, router configuration, set up router, how to set up router, setting up router, router settings</span>
on Jun 10, 2011 | Computers & Internet
Hi i have foggoten my pass word to my router and need to change the security settings to stop some one having access thanks Chris
If some one is accessing the router it's probably because there is NO PASSWORD, on the other hand if you had a password and gave it to that persone and can't remeber it you need to RESET the router to factory default (according to manual) than re-configure the device... (with a good password that you will remember)...
Sep 15, 2011 | Belkin F5D7234-4 Router
My wireless router keeps losing internet signal and kicking me off the internet. I have to reset the router at least once every 30 minutes. Is this a router problem or a problem with my internet provider?...
I suggest that you try a higher channel, like 11. The neighbors thing is the wireless security portion.
Here are the steps that I think are important:
Wireless Router settings:
It is usually easiest to run the install wizard, which you can get from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your Internet Browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit. Look under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. SAVE OFTEN.)
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is typically NOT the security issue.
2. Set a recognizable system ID (descriptive name is easier to find when you need to connect wirelessly).
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits.
Jun 25, 2011 | Linksys Wireless-G WRT54G Router
I am getting ready to switch from dial-up to satellite internet service, I have a Compaq Presario SR1730T and need to know what type of wireless router is best or will any wireless router be compatible????
Usually the internet service provider (even satellite) provides a modem/router to access the internet. This being said to purchase a wireless router must mean that you are going to "broadcast" your satellite internet throughout the house so that others in the house can access the internet.
In that case, no it doesn't really matter what kind of wireless router to buy. Just make sure you connect your satellite modem/router (what they send you) into the wireless router correctly. Also, make sure you put a password on that wireless router so that your neighbors or unknown persons do not gain access to your internet/computer.
Thanks.
Jun 16, 2010 | HP Compaq Presario SR1730T (EK467AV) PC...
Wireless Connection
The WPA code is the password to access the router's network, so it can use your internet connection. As long as the Xbox has both the SSID and the WPA password, it can access the internet through the router.
The SSID ( Chris_PC_Network ) is mostly irrelevant to the network connection, and is purely aesthetical. Its only use is to help users distinguish between different networks (so you don't use a neighbor's network or vice versa).
May 24, 2009 | HP Pavilion dv6000z Notebook
Cannot remember password for my Netgear WGT624 wireless router
  • The default user name is: Admin
  • The default password: is password or (for older routers) 1234
Try the default username and password before resetting the router to the factory defaults.
When a router resets, it goes back to the state when it was new — all information that was entered by hand is lost! Examples are critical things you need to get online, such as ISP username, ISP password, IP addresses, security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
May 18, 2009 | NetGear WGT624 Wireless Router
Router password
Unfortunately in most routers, you cannot actually find the existing password. If you have access to the router configuration, you can set a new Wifi password.
Using a wired connection to the router, you will need to find the "default gateway" of your computer. To do that, go to Start>Run, type "cmd" (without quotes) and hit OK. Type "ipconfig" without quotes and hit enter. It will give you the IP address and default gateway of your computer. Now, go to Internet Explorer or your favorite browser and type the default gateway address into the address bar (no WWW in front of it). Hit Enter on that. If it pops up with a username and password on that, you'll need to get that from whoever set up your wireless router. If it was you and you don't know the password, you'll have to reset the router back to factory defaults by holding the reset button on the physical router itself, while you plug the power in (that may not be the procedure - consult your router documentation for resetting to factory defaults).
If you did know that web password, you can get in and click on something like "Wireless Settings" and look for "Encryption" or something similar, and there will be a place to enter a new password.
Apr 16, 2009 | D-Link DI 514 Wireless Router (DI-514)
I need to put a password on my wireless router so neighbors cannot access my internet connection.
Access the configuration page of the router by typing in 192.168.0.1 on the address bar.
>Type in Admin/admin on your the log-in page and leave the password blank click ok.
>If you created a username and passsword used that one, if you forget your username and password reset the router for 15 seconds. Reset button is located at the back of your router and use admin on the login page.
>Once inside, click on HOME and on the left side choose WIRELESS
>Enables should be choosen.
>Under SSID, change your network name to a new one.
>Under Network Authentication choose WPA-PSK
>Key type would be passphrase
>Type in your password for your network. mimimum 8 character.
>Click on Apply >Continue.
>On your laptop, connect first to your wireless network before accessing the Internet.
Jan 21, 2009 | D-Link DI 514 Wireless Router (DI-514)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
326 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
