Question about Gigabyte Computers & Internet
Screen suddenly goes black - Gigabyte Computers & Internet
    Problem Solver:
  • 9 Answers
The processor may be overheating. Check to see that all fans are running and that the heat sinks are all free from any obstructing lint or whatever. Also check to see that the heat sink is firmly mounted to the processor chip. They sometimes come loose due to their plastic brackets failing. Remounting by alternate means after cleaning the contact surface area and reapplying new thermal transfer paste has been my solution in those cases.
Posted on Nov 22, 2013
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Television suddenly turns black
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 16, 2017 | Westinghouse SK-26H520S 26 in. LCD HDTV
Screen keeps flashing off to black. how to stop
When it goes black does it come back to normal? If so, what did you do to get it back?
Apr 01, 2012 | Computers & Internet
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Stuck on black screen after login
You have a virus. Go to safe mode and reinstall video card drivers.
Nov 29, 2008 | Computers & Internet
Screen Goes Black
it sounds like your "lamp" is going out look for a hidden compartment.. or in your owners manual to see where its located its an easy fix and costs much less than a new tv
Oct 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
Open Questions:
Computers & Internet Logo
29 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
