Question about Jensen Audio Players & Recorders
MY JENSEN VM9021TS SOUND WENT OUT AN NOW A LOUD HUMMING EVEN WITH THE VOLUME AT ZERO
FIRST THE SOUND CUTS OUT, ONLY BASS, OK SO I PULL THE DECK OUT AND CHECK THE WIRES,, EVERYTHING LOOKS OK, I TURN IT ON ITS OK... ABOUT TEN MIN LATER BUMPN IT. OUT WITH THE SOUND AND ALL BASS. I TAP IT ON ITS RIGHT SIDE AND ALL SPEAKERS START HISSING LOUD SO I TURN THE VOL OFF AND THE SOUND CONTINUES TO SCRECH,, I TRY TURNING MAX VOL, NOW I HEAR THE MUSIC FAINT BUT CUTING OUT CRACKLING AND HISSING. WHAT CAUSED THAT? AND CAN IT BE FIXED?
  • 20 Answers
SOURCE: my jvc rx-6010v is OVERLOADING?
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (JVC - and others - say SIX ohms, but 8 is the "standard" you should use.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: The internal overload protection system you mention is designed to help prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized JVC service center must do this. Note, though, that if you have attempted to "cheat" the system several times, damage CAN be done that requires servicing.] But, before you take the unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Posted on Jul 18, 2007
  • 1694 Answers
SOURCE: Denon AVR-1601 Receiver
Check capacitors in power supply......also check for over-heated
resistors..all 1 ohm.....replace if cooked...................T.
Posted on Jan 05, 2008
  • 4234 Answers
SOURCE: MY YAMAHA RECIEVER KEEPS SHUTTING OFF
The unit is going into protection mode. The message is a generic one and usually means that the output section is drawing too much current and has been shut down. Defective speakers can cause this, but in this case, I suspect that there is a problem in the front end that is allowing DC current to pass to the output circuits. This will cause a problem that will shutdown the system. Yamaha designs are not the most straightforward nad I would not suggest you attempt this repair without prior repair experience. Take this to a service center and request a detailed repair estimate and report the results here. Armed with that info, we canguide you further.
Dan
Posted on Jul 19, 2009
SOURCE: Hi, I have a AV-R720
I have the same trouble with my av-r720 .
Did you solve the problem ??
Thanks
Marco
Posted on Dec 18, 2010
SOURCE: Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Posted on Sep 01, 2012
Have a jensen vm9021ts that wont feed in cd's, play them or eject
good day just look for a qualified technician to repair the mechanical problem in your car video player.
Jun 21, 2010 | Car Audio & Video
When i turned the bass up to high on my head unit my amp cuts out on overprotection, just for a second and them comes back on. why?
go into your settings in the deck by holding down the volume on most models for 10 seconds then change your hpf settings and your lpf settings your bass will sound much better and not cut out. hpf recommended 160......lpf recommended 140.... good luck
Jun 03, 2010 | Car Audio & Video
Wanted to adjust quality of sound, such as treble
Go in ur menu pick the audio go down pick the reset the tv set back to factory setting will get the
Mar 24, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Apr 13, 2009 | Technics SA-AX530 Receiver
Losing power
mine does this too, I have the deck on my boat and on land the deck cuts out when a bass line hits or loud music comes in, cuts out at about 20 on the volume level, however, when on the water and the motor is running, my voltage is up to 14 vdc or so.. At this point, I can crank the deck up to 30-37, and it will scream , doesnt cut out or lose power just rocks. I have heard that kenwood decks are competition stereos and require 14-16vdc, but I have never found any proof of this. One thing you can do is order a battery from summitracing.com that runs higher than 12vdc. But then again im just speculating
Mar 05, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
Jenson touch screen head unit is all hooked up properly in a 2001 honda civic if i turn it up to around 25 with loud off and bass down it will shut off for a few seconds and then turn back on and repeat...
the onboard amp in the deck can't keep up and overheats inturn shutting off the speakers , this is common in jensen touchscreens esp the 9412 9512 and the uv 8 best thing to do is buy a 4 channel amp and the problem will be solved sometimes running a bigger constant power wire to the deck will help a little but not much better off buying a 4 ch amp
Aug 12, 2008 | Jensen Car Audio & Video
Cuts out when volume increased
it went to protection mode check your cables first and then check your speakers-and confirm no cable touch each other(try with another speakers had same rating)(watt)--means how much power can get.
Jul 28, 2008 | NAD C320 2-Channel Amplifier
42 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
