Question about Lakewood HV 18-c Floor / Box Fan
What made the cord on the back of the fan to melt together?
The cord that connects to the power source, I guess it got hot and melted together with cord connector
My Toro power blower vac plug got so hot and burned the inside of the extension cord so it melted onto it.
Obviously, that power cord is now shot. But, if you are pretty handy and very confident, simply splice the cord. Make sure you hook up the wires to the correct ones and plug it in make sure it is all electrical tape back together so the wires have absolutely no chance of touching each other, and if that does not work, I would say that there is a defect with the Toro
Dec 02, 2016 | Toro Garden
Blowed head gasket on Hyundai elantria head checked out ok put back together now won't start motor got hot enough to melt plug wires and radiator my daughter's care
You forgot to fill the cooling system didn't you? Or at best, you didn't 'burp' the system and get the air out. Perhaps not enough oil, which also cools?
If it was hot enough to melt the plug wires on the outside I dread to think what the valve or pistons look like. If it melted plastic on the outside, it must be hot enough to melt metal inside.
Dec 07, 2015 | Hyundai Cars & Trucks
What would cause the inside fan motor ( AC and heater) to continue to run after the ignition is turned off
You should take a close look at the wires either at the wires attached to the motor or its fan switch (most likely) and look for one of the wire's insulation to be melted. The most likely scenario is one of the fan's speed control wires is crossed and therefore shorted with a constant on (Wire that is going directly to the battery. You will need to separate the wires and add electrical tape to thoroughly insulate both wires!
Good Luck!
Rich Lilja
Jul 15, 2014 | 2004 Pontiac Grand Prix
Hot plug default
hot , melting cords is an indication of a short in the unit and drawing more power than the cord will carry
it also indicates that the fuse(circuit breaker ) in the house fuse box is of the wrong size and may result in a house fire as if the cord is getting ,then so is the wire in the house to that outlet
have an appliance service centre check it out and have an electrician check out the fuse in the fuse board
Apr 10, 2014 | Applica George Foreman Family Size Gril -...
The refrigerator side is cool, but not cold. The freezer side is frozen, but melting. The ice in the ice maker melted, but created one big ice cycle that has not melted. The fan underneath is running,...
I just ran into this problem this year. Is it very warm underneath your fridge? If you remove the cover in the back, you may find that you compressor is so hot you can't touch it. You can first try blowing out your cooling fins in the back of your fridge. A fan is connected to it and it should be next to the compressor. For my case that did not work. I then replaced the fan for the cooling fins and now my fridge works fine.
Nov 10, 2012 | KitchenAid KSRS25FG
Drill completely stopped working. Bad smell from battery. Charged up the second battery and plugged it in. In three seconds, it started smoking very badly. I removed it. The drill worked with second...
The only way to tell if you can fix it is to take the drill apart...
Look for two wires melted together...my guess is that they got too hot and melted together inside the drill... separate and insulate and you should be fine...
heatman101
May 21, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Melted Power Adaptore on a Asus eeepc 900ha
you need to contact the manufactuer if it melting plasic its gettting way to hot. if it catchs fire they are responsible contact them so they can either repair it or replace it
Vote me 10 for this solution
Jan 06, 2010 | ASUS COMPUTER INTL EPC900HABLK006X: Eee...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Last time used,working good.BUT hot, tuned off normal. Next day wounld not Turn on,but charger light came on and charge batt.to full charge lite came on. TOOK FAN out in middle were heat tranfer white...
1. buy some transfer compound
2. replace the fan and heatsink over the compud do not spread compound with finger.
3. Reset the unit by takeing out the battery and unplugging it from AC source then after a few min. plug everything back in.
4. if that does not work you may have a overheated cpu and this would need to be repaired at this point seeing that the compd was melted off.
Jul 08, 2009 | Gateway MX7118 Notebook
I am having difficulty glueing PVC together. I
3M Hot Melt 3764 is the correct adhesive for PVC.
Apr 22, 2009 | 3M Polygun AE II Hot Melt Glue Gun
Lakewood HV 18-c Floor / Box Fan Logo
20 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
