Question about Oreck XL2200 Bagged Upright Vacuum
Motor wont turn locked up - Oreck XL2200 Bagged Upright Vacuum
  • Oreck Master
  • 932 Answers
Sounds like something was picked up that should not have been and is now stuck in the fan housing. Lay the vacuum out with the housing bottom side up and take out the 5 screws that hold the base plate on and then remove base plate. You should see your intake nozzle that leads to the fan housing and it has 1 screw and the motor has two screws holding it down. Remove all 3 screws and that will allow you enough room to remove the intake nozzle off the machine and that will allow you to see what may be jammed in the fan housing. It might be possible to look through the intake nozzle and see your jam but you still might have to take it apart to get the jam out. Watch carefully as you take the vacuum apart so that you can put it back together correctly. It is fairly simple so you should not have to much of a problem with it and you should only need a Phillips screwdriver and maybe a pair of pliers to remove any jam. Hope this helps!
Posted on Nov 25, 2013
Brush on rainbow will not turn but motor does because it burns the belt
Could be locked up beater bearing. remove beater bar and turn bearing by hand ro see if that is the problem. turn shaft on motor to see if that is locked up.
Jul 20, 2014 | Rainbow E series Canister Wet/Dry Vacuum
We used it then turned it off and went to turn it back on but wouldnt do anything.latches are locked and has water in it. im getting power to the switch
E series vacuums have a safety switch underneath the motor unit to insure the water basin is on. You can see the part here and where it is located (left of the separator)
Rainbow interlock plunger
Sometimes this part may have fallen out and gotten lost when you were putting your vacuum away, or your water basin where it would depress this switch broke of.
If your motor is good and power nozzle is good, it may be this.
GoodVac.com
800-775-6586
Mar 24, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Compact electra C9 vacuum power head wont turn on
Have you checked the electricity is getting to the motor? You can replace the motor if necessary.
Jan 17, 2014 | Electrolux Epic 6500 Vacuum
Beaterbar wont turn and motor just hums like its locked up
it might need a new belt, thats what drives the beater bar from the motor
Nov 19, 2013 | Vacuums
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
DC 17 UPRIGHT BRUSH MOTOR WONT STAY RUNNING. TURN
have a look at the filters first as it sounds like you blokeage
Oct 31, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Spin brushes wont spin and the switch wont turn machine off. I have to unplug it.
for the spin brushes it is most likely the motor is fried if you smell something burning it could be jammed or the wires have be shaken off the motor terminals. for it not turning off you need a new switch.
Jul 29, 2009 | Hoover F7431-900 SteamVac Vacuum
Burning smell, vacuum wont turn on now
the front of the machine ( the peice that holds the brush roller ) and the bag unit are part of a safety system that will only let it turn on if both are locked firmly in place, after checking that examine the cord, look for any burn marks especially at the plug and where the cord clips into the retainer on the handle and if you can where it plugs into the machine but you will probably need a set of torx screwdrivers for that. if there was any funny noises before it shut off the kids could have damaged the motor, and just because the belt isnt broken it can still get burnt and make a bad smell change them ever six months to a year
Sep 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vaccum wont work
There is also a reset button on the side at the bottom. Good luck.
Oct 14, 2007 | Vacuums
Oreck XL2200 Bagged Upright Vacuum Logo
76 people viewed this question
Top Oreck Vacuums Experts
Gerry Harvey
Gerry Harvey
john h
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
