Question about Saws
Engine target wet saw no works - Saws
Does anyone have a link for the assembly manual for this product? We have received it without any.
what kind of wet saw is it? Target? MK? Chicago? there are many different types of saws. 7 in 10inch blades (what i use)
Mar 06, 2015 | Saws
The Target wet saw TA10100 is shutting down immediately after starting up. Anyone know the part that is causing this. We have replaced the off/on switch and repaired a wire to the switch with new conn
check where your power cord goes inside the saw to the motor. All that wrapping the cord around to pack it up sometimes works it loose. Other wise id take it to a elec motor shop for a new motor, Last one i got i think it was $40 installed. Targets arent' cheap so its worth just putting a new elec motor in it.
Oct 27, 2014 | Saws
Where do I buy parts
i beleave target makes husqvarna try that 1st,if not try a tile store that sales saws,1st,try target tile saws i bet they will take care of you
Feb 25, 2011 | Husqvarna Tile Saw Tilematic Ts 250 X3...
My target wet saw, on top of the motor has a part in it that overheats due to getting wet, there are two wires soldered. one labeled E, going to the motor,it seems to be an overload device possibly? I was...
We are currently experiencing a problem with the target TA10100 wet saw. It will start up and immediately shutdown. The local authorized tool repair said that the part encased on the top of the Baldor motor is called a capacitor. we have yet to find out if this is the cause of the problem. Hope the information helps you because so far it hasn't helped us.
Mar 08, 2010 | Target Saws
Need a wiring schematic for a dual voltage masonry saw motor. it s a baldor motor on a target saw
http://us.husqvarnacp.com/
drop down menu "service"
click "service literature"
click "old target, dimas, partner literature"
enter model number
pdf has basic wiring diagram page 4 or so
Dec 12, 2009 | Target Portable Masonry Saw PS1411S...
Need Parts breakdown for this model on a Target brand Quickie Saw Model 12-65
fyi, target tile saws and felker tile saws are made by the same company, and you can find both of them on line. your best bet is to take your saw to a tile distributor that sells saws and they will get what you need , good luck
Jun 27, 2009 | Target Saws
Wobble blade /rough cuts
You may wanna check the Conveyor Cart Wheel. Replacing this wheel maintains smooth rolling action which contributes to straight, chip-free cuts.
It costs for only about $28.72. Here, you may check this link if you wish to buy the Conveyor Cart Wheels:
http://www.diamond-blades.net/target_tile_saw_access.html
Unfortunately, I couldn't find any service center where you can bring your Target Tile saw for repair. But you may check the manufacturer's contact number on the user's manual.
Have a great day!
May 30, 2009 | Target Saws
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
