Question about HP iPAQ hw6515 Pocket PC
6515 wont turn on "help"
I just purchased this on ebay and upon arrival it seems to work fine. I input all my info and my calendar and was ready to insert my old SIMs card. I charged to battery fully then pulled battery and in serted SIM card reinstalled battery and now NOTHING. Is there a reset on this thing?
  • 4,889 Answers
You should try to do a hard reset. While holding down on the far left (calendar) and far right (iTask) press in on the reset button (reset hole) with your stylus for about 2-3 seconds. The Pocket PC should reset and power back on. If the device does not power back on, make sure that the battery lock switch is to the left (locked).
Posted on Oct 09, 2007
  • eagle338
    eagle338 Oct 09, 2007
    I checked up with previous results just now and found this exactly same problem and same solution the problem is solved!click the link below! http://www.fixya.com/support/t205912-som...
SOURCE:
I have a Samsung French Door refrigerator, model RF260BEAESR. The ice maker works. However the water seems to be freezing before it goes into the tray. Is there a fix for this?
Yes. Change water filter and reset the freezer as the coils might be iced up. There are extensive you tube videos on this subject.
Jul 03, 2015 | Samsung Refrigerators
I have purchased the Yadahome family organizer (in iphone app), does my wife have to purchase the app also to be able to "share" inputed info.
She only needs the separate login id to access the information and to share the information. So it is not mandatory to purchase the app again. If you and wife needs to access information at the same time, then you need of apps for her. Else with your app, she can login and "share" inputs.
Sincerely, Thiyaga
Aug 26, 2011 | Yadahome.com...
I cannot watch cable TV on Input 1 when Input 2 is activated.
Tries to reset the tv Tuner board back to factory setting.By go into the tv menu.Go to PICTURE,go down to reset the Tuner board.All the HDMI ports should work now.Not,than the HDMI port 2 is shorted and dead,don't used the HDMI port 2.The tv should work fine,or tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jun 16, 2010 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
My 52" Toshiba DLP just dropped an HDMI connection... There are two connectors on the back, both have worked fine until just now when one disappeared from the inputs menu on the screen.
I'm not sure about your tv model as question post shows it is Toshiba 52HM84 that has one HDMI input at rear and you said 3 HDMI inputs in your tv.
Please unplug tv from wall socket for minute or so to get it reset, replug back in, turn it On and check its HDMI inputs appear or not.
Also check for Reset option in Menu for factory default settings that can also help you to get back disappeared HDMI inputs.
If all that does not solve the issue then it seems hardware problem with HDMI circuit board and tv repairman is needed for visual check to get it fix.
Hope these info will help you.
Thanks.
Jun 04, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
RCA projection, no power, no sound. recently moved.
Ur DM power board have burn capacitors,check for puff up capacitors,and replace it.Tries these websites.Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hp ipaq 6515 is not working
Hi, I had the same problem. I got a new battery from ebay and now it works fine. John
Sep 08, 2008 | HP iPAQ hw6515 Pocket PC
Unlock code for hp iPaq hw6515a
Hi, I just had my hp 6515 unlocked. Do you think my unlock code will unlock yours?
Jan 06, 2008 | HP iPAQ hw6515 Pocket PC
Spares for Ipaq 6515
hi kanchan by going to this site http://www.ipaqrepair.com or http://www.techtree.comyou will get info about service centre's of ipaq on india for more info serach in web . good luck
Jul 02, 2007 | HP iPAQ hw6515 Pocket PC
Ipaq 6515 gps issues
Hello, You may need to go get the update to 5.21 .. heres the link .. http://www.tomtom.com/support/category.php?ID=3&Language=4&FID=3370 Install it and that will help Bob
Jun 10, 2007 | HP iPAQ hw6515 Pocket PC
Clicks when powered on and off; only faint sound from left and right speakers
You may not be using an active input to test. Try attaching an fm antenna and using the tuner. Sone inputs are set to digial and will not make sound with the analog input. The input selector does turn it on. Saves a step.
Sep 04, 2006 | Marantz SR8500 Receiver
HP iPAQ hw6515 Pocket PC Logo
90 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
