Question about Tools & Hardware - Others
Sandpaper keeps ripping - Tools & Hardware - Others
How do i fix the dryer
Hey friend, thank you for your post!
To determine why your clothes may be getting caught in your dryer, place your hand in an old pair of pantyhose or a nylon stocking (one you don't care about ripping) and slowly run your hand along the drum and agitator. Does it catch anything?
Even though you may have felt with your hands, you might have missed something that is causing the rips. The insides of these holes may rust, and material catches it even though you don't feel it with your hands. If you discover a snag, you can simply take household sandpaper and sand the area(s) down yourself to help fix this problem.
The only other option may possibly be to replace large internal components of the tub, which at this point, please reach out to a professional to properly diagnose and repair your dryer. I hope this is helpful. -Matt
Aug 18, 2014 | Frigidaire Washing Machines
Sandpaper keeps coming off while sanding. Why and how can I remedy situation. I was thinking about replacing rubber cover on clamp.
I switched it to a new pad and the sandpaper is still flying off :( I just don't get it the paper is not even half used up. my sander is the hook and loop velcro one ugh its driving me nuts I have to keep buying more sandpaper when the sandpaper is not even worn out! BTW Mines a dewalt hook and loop random orbit sander
Jan 03, 2011 | Bosch 1297DK 14 Sheet Palm Sander Kit
Sheets keep coming off during sanding
The sandpaper will come off for one of these reasons: 1. The spring clips are to loose to hold the sandpaper. 2. You are using sandpaper that the paper's either too thick for the clips to hold it or too thin to withstand the work you are putting it through. 3. (Most likely) You are pushing down on the sander too hard while sanding. These types of sanders work by their own weight with only a little help from you.
Dec 30, 2010 | Bosch 1297DK 14 Sheet Palm Sander Kit
I ripped a peice of board that had a finish nail sticking out of it that scraped the table. How can I repair the table?
you didnt indicate how bad the scrape is but you might want to start with a VERY fine grit sandpaper and smooth it out or if it is deeper, I would remove the high edges and using something like J-B weld fill in the scrape and let it set and then sand it smooth to the rest of the table using a straight edge for accuracy
Oct 21, 2010 | Saws
Bosch WFF2001 - various problems
Replace the washer is my suggestion.
Jun 25, 2017 | Bosch Washing Machines
Have clicking noise on drive side by wheel.
Check for rips in cv boots. If ripped & leaking out grease,it is also letting in dirt which acts like sandpaper. Then cv joint or shaft will need to be replaced. Also check for play in wheel bearings.
Jun 16, 2010 | 2005 Dodge Caravan
Sandpaper keeps come off
probably the typer disk you are using. cheep disks will not stay on long.
Sep 29, 2009 | Bosch Power Tools Sanders Orbital Sanders
Sandpaper sliding off
there isnt enough tension on the belt, hence the side to side movement. keep tightening the spring until it stops
Jul 22, 2009 | Tools & Hardware - Others
RICO AFICIO 6010 KEEPS PAPER JAMMING,AND THE RIP
The Rip needs the system software reinstalled. The jamming could be anything, need more info.
Jun 17, 2009 | Office Equipment & Supplies
Tools & Hardware - Others Logo
27 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
