I have a weathermaker sxc 060- gg. Last year the heat would come on but not get that hot, this year the heat won't come on @ all, just blows cold air. I can smell a faint gas smell when I take off the cover near the hole. What can I do before calling repair shop. We also had our gas shut off earlier this year
The gas line has air in it, Turn the unit off, at breaker or unplug it. Bleed the air out of the gas line, It should take about 5 seconds to bleed. Tighten gas line, Plug or reset breaker and unit should fire.
Posted on Nov 22, 2013
Ice maker
  • 8 Answers
SOURCE: ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Posted on Mar 27, 2008
SOURCE: comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
Posted on Jun 08, 2008
machtcl1
  • 61 Answers
SOURCE: Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Posted on Jan 02, 2009
diths_kri
  • 67 Answers
SOURCE: central heating HVAC blows cold air -
stat or low battery in tstat
Posted on Jan 07, 2009
philbran
  • 242 Answers
SOURCE: Furnace runs constantly since blower motor was replaced
Sounds like they wired it direct to line voltage , it should run through a sequencer or fan relay to cycle on and off , your seq./relay could be stuck closed to but unlikely being it was just repaired , call the service company back before you do anything they are responsible.
Posted on Apr 11, 2009
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a 1999 Caddac DeVille . The AC works fine during the summer but in the winter it won't blow out hot air unless I'm driving. I've let the car run in the morning to warm up but the inside...
your heater core is possibly stopped up if there has been a radiator leak and stop leak has been poured its definetly clogged or could be a faulty thermostat
Jan 07, 2013 | Cars & Trucks
I have a 1992 Lexus 400 sc and the heat blows cold,It blows fine but only blows cold. The car is in good condition, over 200,000 miles. I drove it from California last year so I never knew about the heat...
see if the feed pipes are hot ,if so then its a fault with the operating flap control ,1992 it could be a cable and not vacumn ,just cannot remember all the cars i work on sorry
Dec 24, 2010 | 1992 Lexus Sc 400
Where does the 3 prong inducer plug into? Carrier Weathermaker Model 58SXAO80-GG Serial 1490A02296
Hi, it would either plug into the circuit board/control board, or have a connector of the same, either male or female it would plug directly into. This is a 120 volt inducer motor. Look for the other end of the plastic plug.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Sep 29, 2010 | Heating & Cooling
Heater blows cold air
the heator core has gone out this is a divise that uses hot coolent from the engine to heat the air that blowes tru your vents it is located behind the glove box some times it's tricky to reach look under the hood to find 2 hoses running side by side in to the fire wall on the passenger side to pin point the location
Dec 05, 2008 | 2002 Mitsubishi Eclipse
Intermittent AC and Heat w/ long gaps of hot(for AC) or cold(for heat) air
I had similar problem on my 2001 Insight. Had to replace some cooling system hoses eaten by rodents... Works like a champ again.
Nov 03, 2008 | 2001 Honda Insight
Weathermaker SX Carrier 58SX060-cc-1
Your blower motor may have failed. Check the blower motor for the air circulation and you may find it is hot but not running. Have the motor replaced if this is the case.
Jun 11, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
