Question about Avermedia AVerKey Plus (AVERKEY-PC)
AverKey3 Plus Avermedia was working and I touched the T.V. to turn the volume up and experienced some static electricity. The T.V. screen went red. I tried another AverKey3 and the screen on the TV turned green. Can something happen to the T.V.? As well as try a different AverKey, I also tried different hookup cords. No luck. Any help would be great. Thanks in advance. Patty
  • tgmmsm May 11, 2010
    The system states start in dos mode
    Novelist:
  • 231 Answers
Hi, sorry to tell you this, but static electricity has killed every conceivevable type of electronic device ever built by man or woman. The insides of your TV has very high voltage and the only safe solution is to take it to a repair man. Ask for a qoute before any work is done, try to get at least 2 quotes.
It may be cheaper to replace than repair the unit and with 2 quotes you will know that you are not being conned.
Regards mistyman
Posted on Oct 10, 2007
6ya staff
SOURCE:
AVerMedia AVerTV, Bt878 WDM Drivers
http://download.cnet.com/m15c-avertv-go-007/3000-2110_4-184325.html
updates
  • AVerMedia, AVerTV WDM Video Capture (7130)
  • AVerMedia, AVerTV WDM Video Capture (Silicon)
  • AVerMedia, AVerTV WDM Video Capture (7134)
  • AVerMedia, AVerTV WDM Video Capture (7133/7135)
  • AVerDVD EZMaker WDM Video Capture
  • AVerMedia, AVerTV WDM TvTuner
hope this help you
Oct 06, 2011 | Avermedia AVerTV GO 007 Plus/FM Plus...
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
Jul 11, 2017 | Emerson EWL3706 37 in. LCD Television
Designer 1 touch screen freezes
Static Electricity and Designer 1:
The designer 1 is susceptible to static electricity. They sell static removers for electronics. Try that 1st. Don’t spray your machine, just the rag and wipe the machine. Endust for electronics makes a pump spray and you can even use it on the screen (DONT spray the screen). Then try to recalibrate the screen in the set menu. If you can’t get into the set menu keep trying until you can otherwise, there is a way to get into the service mode to set it.
Feb 25, 2009 | Husqvarna Designer I
Playstation 2 slim won't turn on
try this:
- turn off PS2
- unplug PS2 and wait 1 minute
- plug in PS2 and turn it on
hope this helps :D
Jan 31, 2009 | Sony PlayStation 2 (PS2) Console
Avermedia TV application remote control doesn't repond anymore
you might of uninstalled you ir driver when you deleted the software
Jun 15, 2017 | Electronics - Others
Remote control problem
re-install the software, after completely removing it, registry and all. chances are you may have updated your soundcard drivers, and the avermedia software failed to keep up. alternatively, try looking in your audio devices and multimedia settings. if you are using more than one sound device (you are if you run a tv card, essentially), make sure the audio device selected is the windows audio mapper. this will re-direct all inputs to your output device accordingly, and you will regain control. failing that, upgrade your tv card. they aint all that... :)
Jun 21, 2008 | Avermedia AVerTV GO 007 Plus/FM Plus...
Drivers
Hi
I've fixed this trouble!
The driver fron Avermedia is OK , but software is'n working under XP.
I've fixed this, by means of Intervideo Windv r6. gold   Using windvr6 gold , my Avermedia m135-c card (Hybrid) is perfectly working (analogic and digital)
As usually, Windvr fixes anything!
Regards
HD
Feb 18, 2008 | Avermedia AVerTV GO 007 Plus/FM Plus...
Uniden black 900 mhz basic model
Julie: If you have increased the volume control to the maximum volume position ( the up touch key) and the volume is still low you have probably done some damage to the amplifier circuit with-in the set and it can't be repaired. Thank You. Jerry
Jan 21, 2008 | Uniden Cordless Phone
Avermedia AVerKey Plus (AVERKEY-PC) Logo
431 people viewed this question
Top Avermedia Televison & Video Experts
Joe Negus
Joe Negus
Alun Cox
Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
