Question about Nutrifaster Juice Tree 106-OJ Commercial Juicer
Leaking blendec jug - Nutrifaster Juice Tree 106-OJ Commercial Juicer
How to stop gass from going into mufler on a 6500 champion generaitor when it is not running
there should be a fuel tap directly under the fuel tank. It should not be leaking fuel through unless there is a problem in the needle and seat ( staying open and not sealing off)
Feb 12, 2015 | Champion Juicers
I have lost the jug bin of my juicer (where the fruit pulp goes) and am no longer able to use the product as I get waste every where. Could someone tell me where to get a new one from? I have a JE95B...
I really have no idea where to find a new one, but... I've got Jack Lalenne's Power Juicer, an older model, and I, too, have lost the jug bin. So, what I do, is use a plastic bag. I pull it over the whole opening through which the pulp comes out and add some scotch tape so it doesn't fall off. I'm pretty sure a paper bag could be used, as well. I know it doesn't answer your question, but it can be a temporary solution..!
Sep 05, 2011 | Juicers
My juicer is about 10 - 12 years old and still works okay but lately when I am juicing it sprays juice everywhere from around the top and leaks out the bottom of the blade piece. Is it just wearing out?...
You might have been able to find a replacement seal for the top but if the bottom is leaking that means the seal is gone there as well and that means replacing the container. The real problem is finding any of these. And when you do the cost is going to be as much as a new unit.
I'm afraid the best advice is to replace the entire unit. The only thing is to make sure you buy a quality unit if you want to get any useful life out of them. A cheap unit is going to start leaking within a year or two (about 30 seconds after the warranty runs out) a good unit will give you hopefully another 5-10 years of use.Might cost more now but you won;t have to replace it that quickly either.
Feb 01, 2011 | Breville JE900 Juicer
The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
Jun 20, 2010 | Breville JE900 Juicer
THE JUG IS CRACKED AND WOULD LIKE TO PURCHASE A REPLACEMENT
If its a Brevill have you tried their spare parts section ??
Jun 09, 2010 | Breville Juicers
JE95XL Juicer: i broke my jug...
No good. You'll need to locate your local Breville service center.
Otherwise, refer to http://www.brevilleusa.com/breville-parts/juicing/juice-jug-je95xl59.html as you can order direct!
May 18, 2010 | Breville JE95XL Juicer
Champion Juicer leaking a lot; from screen holder!
I'm having the same problem, the blank screen just doesn't fit the main body that well (I think the body on mine may have been warped by someone putting it in the dishwasher). Since I'm only going to be using my Champion as a front-end for a hydraulic press, I bought some food-grade silicone sealant (from McMaster-Carr or EMI Supply) and I'm just going to permanently attach the blank screen to the juicer body and slide the screen holder over that. There's a new O-ring for the back where the body attaches to the motor that might be needed as well.
May 02, 2010 | Champion 2000+ Household Juice Extractor
HOw do i clean it?
flip down the lever to pull it all apart.
rinse out the lid, food pusher and base(that the mesh filter sits in).
scrub out the mesh filter with a dish brush or the included brush if you have it. be carefull the grater-like parts at the base are very sharp. make sure it's clean by holding it up to the light. if there are any particles left clinging to the mesh it will seriously interfere with the effectiveness of your juicing.
you can line the pulp collecting jug with a plastic bag so that you dont have to clean that out as well.
it's best to clean everything immediately. if for some reason you can't, at least rinse the plastic parts and leave the mesh basket to soak until you can get back to it.
if you have any dried food or staining on any of the parts then a soak in water with lemon juice in it (maybe the juice of 3 or 4 lemons) should help soften up particles and strip away stains.
hope this helps....
Jan 09, 2010 | Breville JE900 Juicer
Leaking dark fluid from motor when juicing
sounds like the start of a horror movie. lol
ok dark? and no cracks or leakage from the juice container? hmm
dark .... ...its gotta be juice leaking down and mixing with the dark grease they use on the bearings.. but this is a wild guess. and i cant think of anything else unless a 100 roaches live inside the motor housing.
get it fixed when it starts to whine or smoke.
Apr 03, 2008 | Champion 2000+ Household Juice Extractor
Nutrifaster Juice Tree 106-OJ Commercial Juicer Logo
Top Nutrifaster Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Nutrifaster Juicer Expert? Answer questions, earn points and help others
