Password change for cisco unysis - Computers & Internet
    New Friend:
DJIDJI
Posted on Nov 22, 2013
How to change a Cisco router password?
If you forget the default password for the Cisco router, first you will need to reset the router for default settings.
After resetting your Cisco router to default settings, go and access the configuration page using the IP address 192.168.0.1
After successful login to Cisco router login page, go for the "Menu" and from here you can find the option to change the password for the Cisco router.
other question, you can visit http://www.router-switch.com/, you can also buy brand new Cisco routers/switches with big discount here.
thank you
Oct 20, 2017 | Cisco Computers & Internet
Tip
Guide to Reset Password on a Cisco Router
How do I reset the password on my Cisco router?<br />I bought a Cisco 1700 router from an auction, but there is a password. How can I reset the router to original factory specifications? <br /><br />Sky sagem wireless router reset password? I just got this sky wireless router second hand and it has a password set on it. i tried to press the reset button at the back but it does not do any thing, it still comes as a password is set.<br /><br />How to reset password on dlink wireless router? I have a dlink wireless router model number DIR 825 . It works good but I am trying to access internet on my ipod and the password i have set is incorrect , this also happened when i tried to access internet on my laptop. When i first set up my ps3 i dont recall having to put a password in but this was when i first got the router. How do i reset the router password or find out what the password is AND if i reset the password or reset my router will my ps3 have to be reconnected or will it stay?<br /><br />How to reset password on a router? I recently acquired a linksys router (used) and need to know how to reset the password so that I can use it. Also, is there any way to modify a router to be useful as a cell/wifi blocker, or as a signal booster?<br />... <br /> ----From Yahoo Answers<br /><br /><br />To reset password on a Cisco/D-link/Linksys/Netgear router is a very common problem among people who want a secure network environment for surfing on the internet. If you are confused with the complicated procedure to reset or change the password on a router, or if you are trying to configure a Cisco router, but a password is blocking you from enable mode, don't worry, just do the steps as follows, password reset on a router is no longer upset to everyone.<br /><br />First, be informed that what you need:<br />.<a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router</a><br />.Computer<br />.Internet Connection<br />.Blue Serial Cable<br /><br />Guide for You to Reset Password on a Cisco Router:<br />1. Download a program called Putty from the first resource site below. PuTTy is a terminal emulator application which can act as a client for the SSH, Telnet, rlogin, and raw TCP computing protocols (PuTTy on Wikipedia).http://en.wikipedia.org/wiki/PuTTY<br /><br />2. Connect one end of the blue serial cable to the Cisco Router and the other to your computer. Open up the Putty program on your computer and select the radio button next to "serial" on the right-hand side of the start window. Click on the "Open" button in the bottom right-hand corner of the Putty start window to open the terminal.<br /><br />3. Power the Cisco Router on. As soon as the router begins loading in the green and black Putty terminal window, press the "Ctrl" and "Break" keys simultaneously until its going into rommon mode.<br /><br /><br />4. Once in rommon mode, you have to change the configuration register number to make the router boot from a blank configuration file. For the 2800 series Cisco Routers, the command "confreq 0x2142", changing the register number to 2142, worked. Search on cisco.com for information on your particular <a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router Series</a>.<br /><br />5. Type the restart command in rommon mode, which is "reset". This will boot the router up again. When it is finished, you should be able to type "en" to get into enable mode without a password.<br /><br />6. Once you change the running-config in RAM and save it to the startup-config in NVRAM, remember to change the configuration register number back to its default (usually 0x2102). This is important if you change anything on the running-config. <br /><br />Easy five steps help you finish resetting password on a Cisco router. Easy instruction, easy to follow. <br /><br />
on Jul 19, 2011 | Computers & Internet
How do I reset the Cisco router password?
Perform these steps in order to recover your password:
  1. Either switch off or shut down the router.
  2. Remove the compact flash that is on the rear of the router. ...
  3. Switch on the router.
  4. Once the router is on Rommon mode, reinsert the compact flash.
  5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
  6. if you still confused, you can also visit Router-Switch, There's a lot of answer about network products, You can also seek artificial services here, they will be happy to help you.
Sep 27, 2017 | Cisco Computers & Internet
Hi, How to change Cisco IP Phone voicemail password on router. Thank you
on the CLI you need to change the username and password on the ephone for that phone. Then you need to session into the CUE module and change the password there as well. do a show run and find the username and password that you need to change and then do config t and change the password. The user can also do this on the phone if they know the previous password.
Aug 31, 2017 | Cisco Computers & Internet
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
Dec 29, 2014 | Cisco Linksys E1000 WirelessN Broadband...
Change password
It would be helpful if we knew the Make, Model of device. Cisco support: http://www.cisco.com/cisco/web/support/index.html Using your model, a User/Setup Manual can be found here.
Apr 30, 2013 | Cisco Computers & Internet
I cant connect with the router because i forgot the password
Default admin username, cisco. Default admin password, cisco
Jul 28, 2011 | Cisco (1841) Router (cisco1841)
I forgot to change the default public credential User: cisco and pwd: cisco. Un fortunately I did restart the router. I would like your assistance to gain access to the router or to reset it back to...
Here is a cisco page that goes over the password recovery procedure. Once you reset the credentials, you can make any configuration changes needed. You will also have the option to keep the existing configuration in place but change the password, if the configuration has any use to you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
Mar 11, 2011 | Cisco (1841) Router (cisco1841)
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
