Ice formation ac indoor unit
Some days AC indoor unit ice form what is reason? how to rectify the broblem
  • 28 Answers
Several issues can cause this problem.
1st. not enough air circulating the evaporator coil meaning dirt filters or obstruction.
2nd. low refrigerant charge.
3rd. the out side tempurature maybe to cold, some units don't funtion well in cold climites.
Posted on Nov 22, 2013
louislevel_2
  • 374 Answers
SOURCE: Formation of ice on evaporator element
hi! there,
eventually ice freezing evaporator occured two factor you have
dirty fin evaporator and undercharge system.
1. undercharge can easily detected using clamp
ammeter clamp on one line of evaporator while running
read the amper the compare this to yuor service
manual the rated current of the compressor.
2.if the reading current is below the rared current on
manual or there is tag on the body of unit specified
rated current.your unit need to recharge.
if has the same current no change at all freon is still
good, this only need cleaning of eveporator fin.
clean this by pressurise water to purge out all debris
particle on fin tube of evaporator.
cracking sound usally made by blwer or fan
misalignement or distorted bearing blower .
regards have anice day dont forget to rate me.
Posted on Apr 10, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
jmgldsmth
  • 1869 Answers
SOURCE: ice formation in the indoor unit
you need to have the unit checked for the amount of freon in the system this must be done with a gauge set the freon amount is obviously incorrect
also the a-frame evaporator must be sealed in the furnace cabinet
Posted on May 28, 2009
crouchdash
  • 83 Answers
SOURCE: LG 18000 ac leaks water in the front of unit.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Posted on Jun 05, 2009
SOURCE: manufacturing defect in samsung air conditioner
ice formation in front portion of window ac. not enough cooling effect.
Posted on Jul 23, 2009
How do i conect the alternater to the battery on a 1973 aermacchi Z90 motor cycle
Technically you can't. A battery is direct current DC and an alternator is alternating current AC. You need to connect a rectifier to the alternator output wires this converts AC to DC then you will need some form of regulator to make sure the current does not overload the electrical system. Most modern bikes have the rectifier and regulator in one unit. Older bikes often had/have 2 units to cover this.
Apr 11, 2014 | 1973 Yamaha TX 750
Hi. I recently installed 1.5 T, 3 * Split AC, LG. Whole day the AC works fine and no problem in cooling too. But once in 2 day outdoor unit start making thudding noise continously and does not stop for 4...
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Apr 08, 2011 | LG Heating & Cooling
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
1.5T Voltas Vetris window AC. Ice formation
I think the more likely problem is that the unit is slightly short of gas\ refrigerant, which is a common cause of icing up evaporator coils and this sound you describe. First check that the air filter is clean. Another cause could be the defrost sensor is faulty, but I would think not. Some ice isn't actually a bad thing, but quite common as long as it doesn't form over too much of the coil, or get too thick.
Aug 15, 2009 | LG Heat cool Window Air Conditioner
Ice formation in the indoor unit
May 28, 2009 | LG Heat cool Window Air Conditioner
hi! there,
Apr 10, 2009 | LG Heating & Cooling
AC is not working for the past 20 days, we have complaint to your office, the serivce person took our ac unit to there workshop and they brought to our house' 19.1.09 still now is not working huge amount...
We are not associated with any manufacturer. We only offer free service assistance. Ice formation indicates insufficient air flow. Clean or replace your air filter. Make sure you do not have unit set to draw in outside air while operating. This should be a Fix-Ya for your air conditioner.
Jan 20, 2009 | Heating & Cooling
Manufacturing defect in samsung air conditioner
Sep 07, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
