Question about Carrozzeria HDD navigation system AVIC-H 99 V77MD
On and Off button
How to switch off the system, its taking the whole power from my battery
  • 508 Answers
Thanks for the picture. It helped, but not by much. This unit i haven't even seen in North America and judging by the fact that steering wheel is on the wrong side of the car i may never see it. However in answer to your question. Top of the unit folds down and slides back into a slot. Should be able to gently pull it forward and then slide it back into the slot that is behind the display screen.
2- If you are not afraid to play with the buttons press them and see what they do. This unit looks like it has a touchscreen so you should be able to exit the gps side of this and go into your music files and other files on the unit. You should be able to find the features and setup screens that you want under the setup menu.
3- These devices are designed so that when key goes on, they go on so if the unit will not shut down when the key is turned off -- it is most likely hooked up to the wrong circuit. Only circuit that should be hooked directly to power is the clock circuit. I could tell you some of the wiring but not sure the European cars are hooked up the same way and follow the same wiring as N American Cars.
4- Sorry it took so long to get back to you but i am a long haul driver and was out of town on a run. Think you call them Lorry drivers over there. If you need more help or think i may help you more feel free to contact me. I do hope this helps you ouyt though.
Posted on Nov 29, 2013
  • Elkan Paruque Dec 05, 2013
    Will, Thanks, point 3 definetely is...I emailed Pioneer and they told me exactly what you wrote on point 3. Nop, I believe its not touch screen I tried it couple of times beacause it was kinder of frustrating me. Drive safely/ always be bolted to the seat belt. Thanks again.
I recently replaced my Intermatic EJ500 with a new unit, I noticed it works perfectly fine for one day then the batteries that control the timer drain completely the following day, what could it be?
Line voltage usually controls the timer functions when properly wired until a power outage occurs; then battery power takes over until utility power is restored. Should utility power be off for an extended period of time, eventually the battery will drain completely
Double check to make sure you wired your wall switch timer properly.
Make sure there are no loose wiring connections.
Even though you purchased a new replacement timer wall switch, it could be a manufacturer's defect.
Has your home electrical system experienced any signal spikes? Electronic components are very sensitive to impulse spikes/surges and can be damaged very easily.
If you are experiencing surges or spikes, perhaps investing in a whole house surge protection system (Intermatic IG series) would be the way to go as well. It'll protect all your electronic devices and appliances through-out the house.
Feb 12, 2017 | Intermatic Hardware & Accessories
My samsung gt-s5300 keeps switching over into a vibrate mode and then the whole phone freezes until i take the battery out and restarts it.It only works for a short while and does the same thing.Is it
Use this method to hard reset your Samsung Galaxy Pocket S5300 phone: Enter *2767*3855# , or use volume up + power + home and wipe data
good luck
Mr Difallah walid
Nov 13, 2014 | Samsung GT-S5300 Galaxy Pocket
Meridian color wil not power on - screen flashes white, then goes off. I think what I did was: got a low battery warning and changed the batteries without powering off first. Please help
Yes it is possible that sense you just changed batteries with out powering it off first through the computer off. Try to reboot it. Meaning make sure it is off of course, then as you power it on, keep the on button depressed through the whole turning on process, even 10 seconds past. Meaning, while it is turning on, you keep your power button depressed or switch on, through the whole process. If this does not work, take batteries out, wait about 15 minutes and try this again. What this does is manually reboot system. Let me know, Thanks Mike from fixya.
Aug 29, 2011 | Magellan Meridian Color GPS Receiver
Water got into system-large volume and now switches on off by itself continuosly only on switch and whole system not coming on
Immediately take out the battery. Let the whole system dry up and get free of any moisture else it will continue to damage your machine. Use hair dryer if needed. Do not switch it on unless it has fully dried up, may take 2-3 days.
Jul 18, 2011 | Compaq Presario Notebook
Honda valkyrie tourer year is 2000. problem is no headlight or spotslights ,,,I did checked the fuse and its ok.
You probably have a bad starter button. It is a two position switch. Push it in half way and it turns off the headlight. Push it in all the way and it powers the starter solenoid. If the button is dirty or broken your headlight wont work. Try cleaning the button. if it needs to be replaced you will have to replace the whole right switch assembly. The spot lights not working depends on how the mechanic wired them into the system. If they were wired to the headlight power source , I believe it was done correctly. Never attach accessories directly to the battery . It bypasses the voltage regulator and wil damage your battery through overcharging.
Dec 28, 2010 | 2000 Honda Valkyrie Interstate
My IBM T30 Think pad lap-top is stuck in power save mode.The battery is still charging fine,but the whole screen is black with no image when i turn it on.However when i switch it on,all the leds light up...
Try to power drain the motherboard.
please follow this steps:
unplug the power adapter
press and hold power button for 30 secs
put everything back in
power on the computer
if issue is not resolved. There could be a possibility that this is LCD problem.
May 21, 2010 | IBM ThinkPad T30 2366 Notebook
Hi in my apc es 500 the amber and green light is alternatively flashing and my ups is not working on battery power it is shutting down automatically plz help
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
These lower powered and cheaper type UPS are switch over types, when the mains supply fail, the UPS switches over to the battery and inverter in milli-seconds which then supplies mains power. A faulty inverter circuit and or flat batteries won’t deliver standby power when the mains supply fails.
Nov 12, 2009 | APC Computers & Internet
My ups is not working. it is not responding on main power supply neither backing up.
These lower powered and cheaper KVA type UPS are switch over types, when the mains supply fail, the UPS switches over to the battery and inverter in milli-seconds which then supplies mains power but the power waveform is a pseudo sine wave (ie not a true sinewave. A faulty inverter circuit and or flat batteries won’t deliver standby power when the mains supply fails.
Nov 07, 2009 | APC Back-UPS CS 500VA UPS System
Carrozzeria HDD navigation system AVIC-H 99 V77MD Logo
80 people viewed this question
Top Carrozzeria GPS Experts
Will Halftowaite
Are you a Carrozzeria GPS Expert? Answer questions, earn points and help others
