Question about Kenmore Refrigerators
Kenmore elite crisper tilt out cover with button for model 79577243601
The release and lock button broke need to replace either JUST the button, the cover or the whole tray.
  • 42 Answers
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Posted on Jan 11, 2009
kaycee71
  • 37 Answers
SOURCE: I have Kenmore refrigerator,leaks water inside.
Is there an ice maker in the freezer? If so, check all fittings, otherwise, this is condensation, which is VERY common & is actually expected, especially in summer months. There should be a small hole in the bottom, center, under the crisper drawers, make sure that it is not blocked up. The condesation (water) that builds up goes through that hole into a condensation drain pan & gets cooked off by a little boxy thing (golly I forget the correct term & my husband is a refrigeration tech) that warms up or simply evaporates in to the air. The water you see is NORMAL, but your drain may be plugged up, so go have a peek to make sure it's clear, if not, just clear it out & you'll be good to go. Good luck.
Posted on Aug 29, 2009
woodchuck789
  • 4059 Answers
SOURCE: kenmore refrigerator model 253.71832104.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Sears Kenmore Elite Refrigerator - Model
It appears your selector microswitch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
Control locked light is on. Have replaced control board but control still locked
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
May 28, 2015 | Whirlpool GEW9250 Electric Dryer
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Elite 45986 Front Load Washer: HI My lchild lock was activated on my kenmore elit...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore Elite 45986 Front Load Washer
Outside plastic cover on door of Kenmore Elite HE3T broke off and I don't know where to go to find a replacement cover.
Go to Searspartsdirect.com and list the (xxx,xxxxxxxx) model number. Then select the proper sub assembly to find a description of the part and it's number--order from that site.
Nov 25, 2009 | Kenmore Elite 45986 Front Load Washer
I'm trying to REPLACE MY BROKEN crispers for my Kenmore Elite refridgerator model #72206200 ,series EM1536186
We have parts and supplies for your Kenmore Elite refrigerator!! What are the 3 numbers before the 722 on your model number? You can call or email me to give me this information and I can assist you as soon as you do.
Sep 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore Elite Washer model 48051. I am
i think the dl code is clogged water pump,tip it back and you can remove the water pump cover and check it-mike
Jul 17, 2009 | Kenmore Washing Machines
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Kenmore elite fridge crisper drawer freezing stuff
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
