Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
this message comes up if you have dropped your camera. try tapping the device while the message comes up. if that doesn't work then you have to take it to the sony service centre to replace the lens array. it costs about 60$ to replace it.
I found this site to solve this problem. I got as far as tapping the lens, while turning it off. That worked but I still could not take pictures, so, I got the idea to put slight pressure on the lens when turning the camera on and was delighted to see that the error message was gone. Then, reluctantly, I snapped a picture...It worked. Hope this helps u 2..
When I transferred those particular pictures to my laptop for some reason they were partially deleted from the camera which gave the 'picture error' message. Deleting that picture completely got rid of the message.
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Had the same problem, turn on camera wait until power up is complete and turn it off again. Give lens area a firm hit and turn camera on error should be fixed. try several times as it may not work first time. This worked for me hope it helps
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
