Question about Fujitsu AMILO Pro V2055 PC Notebook
Taken out cmos and ram sticks,switched on and still gives 3beeps,3beeps,1beep
Should it still beep the same with the cmos and ram removed.
  • 107 Answers
Try to change your RAM . Or if u have more than 1 RAM try to isolate the problem by putting in the 1st stick then try to boot it up. Hope it helps
Posted on Nov 22, 2013
Testimonial: "I"LL TRY THAT AND POST LATER.THANKS."
Air con switches of when on heating then starts beeping 1beep 2beeps 3beeps
Some units emit a flashing code. Check your manual to see if the flashes represent a fault code.
Apr 22, 2014 | LG Heating & Cooling
Phoenix bios
Are you sure this isn't a 4 beat sequence? such as 2-1-2-1?
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
Hp pavillion dv6405us error beep code 3 1 4 3 - what does it mean? how do i fix it?
Sounds like a Phoenix BIOS Beep Code, but the 3beeps-1beep-4beeps-3beeps code doesn't come up,
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N908
[ + Beep codes for Phoenix BIOS (for older PCs) ]
1) Has the inside of the computer ever been cleaned?
2) Clean the gold plated contact pins of the Ram Memory modules, ('Stick'), and reinstall.
2a) Use a pencil eraser to clean the gold plated contacts,
Remove ALL power. Remove the AC adapter (Charger) and Battery.
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
If using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band on the pencil contact the gold plated contact pins.
Rub up, and down gently on EACH contact pin. (Both sides) Doesn't take much to clean them. They may not look shiny, and bright when you are done, but I assure you they are clean.
Handle the ram memory module by the BODY. The Body is everywhere on the ram memory module except for the gold plated contact pins.
The Body is coated with a see-through protective plastic.
Use air to remove the eraser dust before reinstalling. If you have a can of compressed air for computers available, use it. If not air pressure from your mouth will be sufficient.
http://www.youtube.com/watch?v=f7sRPDmcE9o
1a) The cooling system uses air to cool the hardware components inside your laptop.
If the cooling system is clogged with 'Gunk', and cannot adequately receive the needed air flow, the Processor and graphics chipset will overheat.
['Gunk' = Dust, dirt, hair, lint, carpet deodorizer, food crumbs, etc ]
The Processor and the graphics chipset (G.P.U.) are the two hardware components that give off the most heat.
Having the laptop dirty inside can cause a serious issue also, and especially on the Pavilion dv6000 series of Notebook PC;
The graphics chipset is mounted to the motherboard with a BGA surface mount. Through constant overheating of the graphics chipset, the solder joints (Connections) may partially melt, then re-solidify when the laptop is turned off. (Cools down)
This cause cold solder joints of the graphics chipset to motherboard, and a poor contact of graphics chipset to motherboard.
The problem with the Pavilion dv2000, dv6000, and dv9000 series of Notebook PC's, is inadequate cooling for the graphics chipset.
1) http://www.youtube.com/watch?v=JEpnqhRYGLw
2) Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
3) The integrated circuit, or chipset for graphics; is the graphics chipset, or G.P.U.,
http://en.wikipedia.org/wiki/GPU
4) Video showing an average BGA (Ball Grid Array) Rework Station at work, and showing the Solder Balls, and Copper Pads of a BGA surface mount,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll down, click on the Red -
Take a few minutes to view the IR 650 demo video
Regards,
joecoolvette
Sep 18, 2012 | HP Pavilion DV6405US 15.4" Notebook PC PC...
My hard drive doesn't boot up as normal. When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps. Numbers 3 and 4 on the hard drive are...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 29, 2010 | Computers & Internet
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
I have dh55tc, i7 860, 4gb transcend ram, xfx hd 5770, tagan stonerock -u37 600w psu, Its assembled in March 2010 & ran fine for 5 months. One day while watching movie it suddenly froze, i restarted...
3 beeps means that it's a RAM fault. If your memory worked just fine in another pc then it's the fault of the memory controller of the chipset on the motherboard - either the memory slot is loose (move the stick in the slot and try again) or the chipset itself is failing. That can't be fixed, the mobo is dead, replace it.
Nov 19, 2010 | Intel DH55TC Motherboard
When i on my pc normally 3beeps but i only heard 1beep and nothing shows on the screen
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Oct 08, 2010 | Acer Computers & Internet
1 beep 5beeps 1beep 1beep
Try remove the ram and clean the part and put it back ,.
Dec 02, 2009 | Intel Server Board SDS2 Motherboard
Fujitsu AMILO Pro V2055 PC Notebook Logo
93 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
