NEMIC LAMBDA PS-10-24
WE NEED MANUAL BECASE WITCH IS INPUT WITCH OUTPUT
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
Here u go: Nemic Manual
Posted on Nov 24, 2013
I have a hcdh771 compact system and I want to add a Sony ps-lx52p turn table. Can you please help me do this.
You need to buy a phono preamp to add in between the LP player and the music system. Can connect the LP player output to the phono preamp input and output of the preamp to the aux input of music system.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 18, 2016 | Sony Audio Players & Recorders
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
My power shuts off after 2-3 seconds
Hi:
This usually an indication of a power supply problem, have the PS checked for bad capacitors in the output section of the PS.
Jan 24, 2011 | Sharp LC-15AV4U 15 in. LCD Television
V40 direct injection gdi . rich running & lumpy idle
replace lambda probe expensive but it will run ok after that, i dont know if you know how they work so here's a brief: lambda tells ecu how rich the exhaust gasses are, ecu ajusts fuel input as neccasery eg lambda says not anough fuel ecu puts more in and the other way round.
so if your lambda is covered in **** when you get it out just clean and put it back, if it looks clean enough it needs replacing!! jezza
Feb 09, 2010 | 2000 Volvo V40
How do i connect my dvd player up to my tv and direct tv?
Hook your coax cable output from sat. to input on tv, then hook your rca cables from dvd output to input on sat. There are several way to hook one up depends on witch hook ups you have , If this don't work or you don't have theese hookups or wann use different hook ups email me at metallica@tds.net
Oct 06, 2009 | Televison & Video
How do i wire in a Zn-4088 Xlopd sub/amp?
I also bought one and it came with no instructions either.
Should be pretty simple but if you want to control the On/Off of it by the head unit you will need to use a relay,
Sep 24, 2009 | Car Audio & Video
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Dec 27, 2008 | Lexicon Lambda Usb Desktop Recording...
Lambda lexicon sound problems: is vista the cause?
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
Jul 16, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon lambda no sound during playback
AFTER you open a new poject go to "Devices" then "Device Setup" click on "VST Audio System" then on he right side where it says "ASIO DRIVER" make the selection say "Lambda ASIO" then click OK
Jun 05, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
