Question about Zodiac Duo Clear System Chlorine Generator
No flow light lit - Zodiac Duo Clear System Chlorine Generator
    Top Expert:
  • Zodiac Master
  • 7,919 Answers
If water flow check sensor
Posted on May 30, 2016
Pilot lights are lit gas flow is low top of burners are lit bottom of burners are not
Anytime a gas burner is only half lit, I start to look to clean the burner. More than likly the gas ports are clogged and impeding gas flow. Try cleaning and see if that improves. Work of caution, if you clean, need to wait 24 hours to try. Any moisture will stop gas flow. Good Luck
May 23, 2016 | Kitchen Ranges
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
Village series QV32B pilot light won't stay lit
Classic symptom of a malfunctioning thermocouple. When you press the knob, you force the gas valve open so gas will flow. The function of the thermocouple is to confirm that the pilot is lit and allow gas to continue to flow when you release the valve. A new thermocouple is not that expensive. Good luck!
Jan 05, 2015 | Heating & Cooling
Why will my hayward h 250 millivolt pool heater pilot light not stay lit
Looks like your pilot generator may have some corrosion on it. Follow the stainless steel tubing on the gas valve as it goes down to the burner area. At the end of this is the pilot assembly. If you can remove this so your able to work on it you will se a short metal rod that the pilot flame touches when lit. This generates current that keeps the gas flowing to the pilot to keep it lit. Take some sand paper and give it a light sand to remove any corrosion on it. Reassemble at put it together. You may also need to clean the pilot tube(stainless tube from valve). Small spiderwebs can reduce the flow to the pilot and cause this problem also
Jun 25, 2014 | Hayward 250kbtu Ng Pool Heater - Inground
When I turn the heater on, I here all the switches during cycle up but the gas never ignites. after a few minutes the furnace cycles down. The blower fan and AC work fine.
Make sure the pilot light is lit. if the pilot light is not lit I believe there is a safety switch that stops the flow of gas to prevent filling your home with it.
Mar 22, 2011 | Heating & Cooling
The heater is attached to the propane tank properly; however, when I try to light the heater, the push valve does not allow the gas to pass to the heater to be lit. I do have all of the valves open on the...
Typically there is a safety device directly above the pilot light that must be up to temp for the gas to flow. You did not specify if the pilot is lit. If not, hold the lighter at the pilot light while depressing the button for one minute. This allows the sensor to warm to operating temp, thus allowing gas flow. Once pilot is lit adjust the temperature accordingly.
Feb 19, 2011 | Heating & Cooling
Grill doesn't stay lit for the first 20 times, then does
regulator, is faulty, you need to replace it.
Apr 06, 2010 | Weber Q Grill
Burner will not stay lit
try to replace the regulator on the grill
Mar 20, 2010 | Ducane 30400042 (LP)
Zodiac Duo Clear System  Chlorine Generator Logo
288 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
