Question about Jensen 8.5" Overhead DVD Player Package (MVB85) Car Monitor
DVD player will not accept a disc
I have am overhead DVD player in my mountaineer and it has stopped working (i.e will not load a disk just kicks it back out). I was told the best thing to do is replace it. Can someone provide me with instructions on how to actually replace the DVD system?
2 Suggested Answers
rteemon
  • 578 Answers
SOURCE: Our Jensen overhead dvd player wouldn't eject the
you have a a problem with unit best solution replace unit short out in one of it circuit
Posted on Jun 27, 2009
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
Panasonic dvd player in car
see the cause and remedies:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
  7. rollers in PLAYER car, is worn or defective.
  8. use clean disk cleaner for to clean the OPU optical pick up or lens. see the block similar to dvd player conventional
Jul 20, 2012 | Panasonic Televison & Video
Player makes lots of noise when trying to load a disk, some what of a grinding sound and eventually stops with the disk not loaded
hello,
there seem to be a problem with the lens of the dvd player so it is not accepting the disc that is why it is making that grinding sound.
the lens could either be weak or dirty.
try use a lens cleaner, if it works after then it means the lens was dirty.
and if it does not work, then it means the lens is weak and needs replacement.
take care
May 30, 2010 | Denon DVD-2800 DVD Player
Will not accept dvd
you've got a bad player. the motor inside that plls in the disk and spits it back out is toast. replace the dvd player
Feb 16, 2010 | Nesa Vision NESA NSCM-1040 Overhead Flip...
Philips DVP5140 region-free DVD player: NO DISC
You could try cleaning the laser using a laser cleaning disk. Most of the time when it cant read a disk its just because the laser is dirty. If that doesn't work it could just be a faulty laser
Sep 21, 2009 | Philips DVP5140 DVD Player
''Wrong Disk'' error
KM,
You'll need to check the region code of your player.
Make sure you have no discs in the player, and unplug the unit.
Plug it in and turn it on.
Open, then close the tray (with no disc!)
Press the Setup button, then select Load Setup
Press the Enter
While it it loading, press Menu.
When the box appears with a number, confirm it says 1 (region code 1 = USA). If it doesn't, please change it to 1 using the Up / Down buttons.
Press Enter to accept the change.
Jul 07, 2009 | TruTech DV288B3 DVD Player
Disc not loading
You're going to have to switch off the unit and turn it back on to make it stop. the disk is either badly damaged or the infra red in the remote isn't responding to the dvd player vice versa. hope i managed to help. goodluck. PS also clean the lens of the player as dust causes disk loading probs aswell
Mar 30, 2009 | Televison & Video
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | Televison & Video
Jensen 8.5" Overhead DVD Player Package (MVB85) Car Monitor Logo
42 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
