Question about Refrigerators
Eurocave v283 The control panel lcd is flashing. The display is alternating quickly between 20:3 and U I:E c.
How do you remove and replace Eurocave performance control board Eurocave 283
The control panel is held up by two hidden screws (that are not removed) that slide into slots of the top front of the panel and 2 removable Philips screws at the back of the control panel which hold up both the controls and circulation fan.
Unplug the unit. Open the door, remove both chrome screws in the ceiling behind the control panel and put them where you can reach them.
While holding up the fan assembly, slide the control panel forward. It may bind a bit so work it forward carefully to prevent scratching the black finish.
As you pull it forward the fan will want to drop down, so once the control panel has moved forward enough to clear the fan panel (about 1/2") you can insert the screws and finger tighten them to hold up the fan as you remove the panel.
Label the wires before unplugging as they are not all individually keyed and look very similar. Note any unused connectors. You need to unplug the large black power connector, black wire for fan connector, and a white temperature sensor wire(s) before removing the panel. You can leave connected the white wires for lights, display and local humidistat that are part of the panel until the panel is removed.
The power supply board and display board are mounted to the control panel assembly with screws and connected by a ribbon cable and wires. Label any remaining connectors and wires before removing the circuit cards. I think the ribbon cable is only removable on the display board and permanently attached to the power supply board. There are replacement parts available from WineEnthusiast.com as well as 3rd party Eurocave circuit card repair services you can find on the internet.
When reassembling follow the opposite order and note the fan panel mounts ABOVE the control panel on the ceiling of the unit. Gently slide the control panel into backwards into place lining up the slots onto the fixed 2 screws while holding up the fan panel and then install the 2 screws behind it to hold both in place.
Jul 05, 2014 | EuroCave Performance 283 Wine Cellar
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
* Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control)
Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control)
* While holding the above buttons, plug in the TV.
* The TV will turn on with the "K" or "K123" appears om screen.
* Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Tv is not responding to the remote
Look on the side/back of the set for the control buttons. Try them. If they work, then you can do a quick check of the remote by;
Get a digital camera (turn on) and point the remote at the lenses.
If you see a flash on the lcd display, the remote is giving a signal and the problem is probably in the remote sensor on the set.
If you do not see a flash the remote may need new batteries.
No camera? check the batteries anyway.
Feb 13, 2011 | Sanyo DP26648-R 26 in. LCD TV
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
No pic
That means hardware failure. It's the same indicator used on almost all sony products.
Dec 17, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
My Canon Pixma MP170 printer is showing error code 5800, What must i do to fix this?.
MP170 (5b00) Ink Tank Full Error Reset
1,power off.
2,hold stop/reset ,hold ON/OFF
2,release stop/reset, push stop/reset twice, quickly, then release ON/OFF
3,wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
4,then push power twice, quickly
5,power off and power on.
Jul 15, 2008 | Office Equipment & Supplies
Power light flashes
I have an older 20" display. I have had this same problem on occasion, and coincidentally, just experienced it again this morning. It seems to occur after I do an OS update. I powered down the computer, disconnected the display, reconnected by pushing firmly into place, then powered up. The flashing stopped and the display works fine. You might have a different problem, but that simple solution worked for me.
Jun 11, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
