Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Vax V125 all terrain carpet washer-brushes don't turn when machine is switched on
Brushes not turning so carpet not being agitated -nothing appears to be caught on brushes and they turn freely by hand.Is there a hidden belt or motor that turns the brushes as I have checked filters etc and can't find the problem.
Agent Don
  • 310 Answers
SOURCE: brushes not going round
The brushes on my dyson have stopped going round. I have checked it and they move freely by hand. The belt is intact. What could the problem be? The Hoover is about 10 to 12 years old.
My dyson is a dc04
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
One of the main problems with vacuums are that the flat belts on the vacuums stretch and should be changed every 4 to 6 months or 3 or 4 times a year – you can tell by taking off the belt or belts on the vacuums and compare them to the old belts on the vacuum the new belts will fix inside of the old belts and you will be able to see the difference on how much they have stretched – if the belt is a geared belt – they stretch as well but should be changed about one a year – the cost is not that expensive and you cleaning will improve almost double – this also applies for the Dyson DC04 and the Hoover vacuum as well – some of the Hoover vacuums have two (2) belts and they both should be changed @ the same time.
Posted on Apr 15, 2008
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/
Posted on Jul 05, 2008
SOURCE: DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Posted on Dec 23, 2008
Vac Belts
  • 701 Answers
SOURCE: Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Posted on Dec 05, 2009
SOURCE: Brush roller won't turn
On my Dyson, there is a brush reset button on the top right hand side (if you are looking at the front) that you can press to reset the brush. I was vacuuming and too lazy to move a toy and this worked for me once I freed the rope from the brush.
Posted on Mar 16, 2010
Vax C88-P6-T brushes not turning on floor & carpet head
Small brush drive belt may be gone or out of place
Oct 05, 2014 | Vacuums
How do I adjust the height of the brushes and suction
look for a blockage -something may have dislodged the lever mechanism, or be stuck preventing the roller or position leaver from moving.
Sep 26, 2014 | VAX Appliances Vax X5 Bagless Upright...
Carpet washer brushes stopped spinning
Unplug it, turn it over and there should be some thing stuck in the roller brush.
Mar 14, 2014 | VAX Appliances Vacuums
Vax Problems> The front brushes on my Vax V124
before it stopped working did it smell like burnt rubber at all if so its the belt
Jun 05, 2013 | Vacuums
Vax match won't discharge solution or water
please see the videos for troubleshooting and help:
http://support.vax.co.uk/help-videos
God bless you
Jul 24, 2012 | Vacuums
My vax rapide xl ultimate v-027y brushes not working..new belt fitted and same problem
hello i have a vax rarid xl carpet cleaner when you switch power on just makes a buzzing noise can you help thanks
Jul 15, 2012 | VAX Appliances Vacuums
Vax rapid ultra brushes not turning
Dear Sir:
1) Test the power cord for defective wires, broker,or loose repair
2) Test the switch for open see the diagram
3) See if there are some open fuse.
4) See if the belt is broken, replace.
5)Test the input voltage motor.
God bless you
May 26, 2012 | VAX Appliances Agilty V123 Upright Wet...
Panasonic upright vacuum brushes dont turn
This may be too obvious, but do you have the Carpet switch turned on (bottom left of vac). Agitator brush does not go around if Floor/Tools is switched on,
Apr 26, 2012 | Panasonic Bagless Upright Vacuum Cleaner ...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
185 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
