Question about Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
Electrolux ei26ss55gs6 problem started sporadically, changed filter,now on ice at all being made
  • Official Brand Answer
  • 4,342 Answers
Good Morning Denise, thank you for allowing me to assist you!
If your ice maker has stopped producing ice completely, please check these tips, in this order:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
Also the water shut-off valve or water-inlet valve, or both, may be faulty and if necessary either parts may need replacing. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it after proper diagnoses.
Best regards!
Posted on Nov 26, 2013
Electrolux ei26ss55gs6,makes ice ,then will not
Might besetting and adjustment problem .lower the temperature in the fridge
Dec 06, 2013 | Electrolux EW23CS65SS Stainless Steel Side...
Electrolux Pure advantage water filter
Open and shut the water valve quickly to verify the water supply, it could be a bad water supply valve. Bench test the filters for flow or obstruction.
Aug 01, 2017 | Electrolux Icon Freezers
Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Jan 10, 2012 | Electrolux Refrigerators
Electrolux will not make ice. the water will dispense
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 17, 2009 | Electrolux EW23CS65SS Stainless Steel Side...
Water filter problem
sometimes the bracket that you mount the filter to is damaged and needs to be replaced do you still have ice production ?
Aug 10, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Changing water filter in Frigidaire fridge every 3 months
You should change out the water valve on your refrigerator. The filter shouldn't make any difference on the flow. We have parts and supplies for Electrolux, so call us with your model number and we'll be sure to get the correct water valve out to you right away!
Jul 07, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Won't make ice
Have you changed your water filter lately. On many side by sides there are built in water filters that will slowly stop making ice and giving water because the filter is in need of changing...if this is not the problem write back and I will walk you through the other possibilities...
May 18, 2009 | Electrolux Refrigerators
Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
134 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
