Hyundai tv firmware
TV ok at first, then after 5 mins or so the Picture Freezes with a Buzzing noise. My Firmware is V1.0. Do I need the latest Firmware to fix problem?
    Top Expert:
  • Televison & ... Master
  • 75,304 Answers
It sounds that the fault is not with its firmware. Check all the solder terminals at its main board, and power supply board, for any loose solder points. OK?
Posted on Nov 22, 2013
  • dandy_russel Nov 22, 2013
    Ok, Thanks for Info. Will keep you updated .
    Hello, Resoldered a couple of suspects with my SMD iron. Re connected connections. Now seems to be working fine, been switched onh for a good hour now. Thanks for your help. I was going down the wrong route with the firmware i guess.
5 Suggested Answers
SOURCE: HDMI crap out
I got the solution. Contact Customer Service, ask for LEVEL II Tech, and ask them for the old firmware. It will take a lot of pressuring, but they will send it to you and then it will work fine!
Posted on Feb 26, 2008
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
SOURCE: Firmware update caused static on the display
See previous comment
Posted on Nov 19, 2008
SOURCE: The firmware do not finish.. just turn off and
Unplug the ac power cord from the wall for 30 seconds then hold down the power button on the tv, not the remote, and while holding down the power button plug the ac powercord back in and continue holding the power button untill the tv turns on. This is a hard reset back to factory defaults.
Posted on Mar 17, 2011
Latest Firmware for Nakamichi Smart TV
Hi Asad
Why would fixya keep firmware for a Nakamichi TV
Nakamichi web sit would be your best bet!
If they don't have it.........
Sep 24, 2015 | Computers & Internet
I have an Olevia 537H TV from 2007. I would like to download the latest firmware for the unit in hopes it will correct my audio issue on NBC only whereby the music drowns out the people speaking. All other...
Before updating the firmware, you should know about the version of the firmware now running with your TV. Without knowing it, and updating the firmware; might cause the set to get irresponsive to any external commands. So beware before updating. After make sure about the firmware now running, check the site linked here to get latest firmware update to your TV. It will be best to contact any service technician in this case, I suggests.
Electro help
Olevia Driver Firmware Manual
Jun 06, 2014 | Televison & Video
No picture
It's obvious that the power supply failed. The most common parts in a power supply are a thermistor or a voltage rectifier, possibly even a voltage regulator. diodes or resistors can act as fuses too. A ringing sound can come from a fixed coil that isn't kept still with enough epoxy. Hope this helps.
Nov 26, 2013 | LG 50PS60 50 in. Plasma HDTV
My tv have a very typical problem it goes to blank screen but the power is on after few seconds it came back as usual ok. this problem comes down after running more than half an hour constantly.
First make sure you have the latest firmware for your tv by going to Panasonic website. Go to the support part of the site an look for any update in firmware.
Once you have the latest firmware and if the problem persist, try to look for any source of heat close to your tv and eliminate it.
If none of the above works, contact your retailer for a repair, this looks like a overheating problem.
May 07, 2011 | Panasonic PT-44LCX65 Television
Picture freezes
Contact your LG dealer for a service engineer, the software version currently in the TV may need updating, there is an update available for picture freeze problems.
Jan 08, 2010 | LG 42LG30 42 in. LCD HDTV
Game freezes when 'ps' button is pressed
perhaps your ps3 need a firmware update...enter in sony official website and download your ps3 latest firmware...check if your ps3 hdd is ok...bad hdd´s can cause game freeze...
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Picture takes 1 min to show up on TV thru HDMI
There are firmware upgrades on (some) receivers, call customer support for Denon, or an authorized service center. They can help you over the phone. If you need more help, post a comment and I can help you further.
Aug 05, 2009 | Denon AVR-2307 Receiver
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Philips 42PF9630A
Go to philips website and download the latest firmware and install via usb. The fw corrects random power on and offs. If that doesnt fix your problem, the tv is going into error protection mode do to a voltage problem detected by the power supply.
That will be hard to diagnose as everything will test ok as it works before shutting off. The best way is to run the set and use a temp gun to find out whats overheating and go from there.
Aug 04, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
