Question about Denon Ah-p372 Headphones - Black
Left ear speaker broke off - Denon Ah-p372 Headphones - Black
Left headphone doesnt not work
It is in your connection either at the plug in or where it connects to the speaker.
Jul 26, 2014 | Steel Series SteelSeries 7H Headset -...
My beats broke
Mebbe ya burned out a wire
Jan 19, 2018 | Cell Phones
After soldering, my left ear piece sounds lower than the right piece
More likely the heat from the soldering iron has damaged the earpiece speaker. The cone is plastic film.
Oct 03, 2017 | JVC Air-Cushion Headphones HA-FX66W
Left earbud completely silent.
Hi,what makes the left hear completely silent it because the wire inside the left side ear bud might have cut and it's not contacting with the speaker inside the ear bud.
What you will do is this, open the left ear bud that is not working, check if the connection is not properly fix. Also after checking if the wires are intact, if the wires inside are intact with no trace of cut inside,that means that the speaker inside is damaged and will need to be replaced..
If you can't do it your self, I would advice you contact a skilled personnel for help.
Thanks for using fixya....
Oct 21, 2010 | Shure (E2G) Consumer Headphones
I have broke my headphone? now what can i do
depends on where it is broken and whether or not they are ear buds. ove ear headphones or even the on ear, can be easily repaired by soldering the leads back onto the respective speaker. however ear buds tend to be a bit tougher for a novice to solder. if you broke the cable off of the connector, you are better off buying a new pair of headphones modern wires used in the cables for headphones is coated with a colored (or clear, for the grounds) lacquer that is hard to clean off and still get a good connection. good luck, and i hope this helps.
Apr 13, 2010 | Philips GoGear Flash MP3 Player
My turtle beach X1 left headphone and microphone has stopped working have you got any ideas why or somewere that could fix it ? Many thanks
Why don't you contact Turtle Beach directly? You probably broke a cable or something. They have replacement parts on their website.
Actually, to test the headphones, plug in the green jack and USB to your PC and listen to music. If both speakers work, then the headset is fine.
Apr 06, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
Left ear no music
Before you worry about repair, verify that the balance control in the iPod isn't causing the problem. The easy way to do this is to try some other audio device (home stereo, etc).
Mar 19, 2009 | Coby CV-190 Consumer Headphones
Denon Ah-p372 Headphones - Black Logo
13 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
