Question about Fujitsu Siemens Amilo Pro V2055 V2030 V2035 L1310G FAN
Phoenix bios 3beeps 3beeps 1beep
  • 46 Answers
Are you sure this isn't a 4 beat sequence? such as 2-1-2-1?
Posted on Nov 27, 2013
Testimonial: "definitely 3 3 1"
Air con switches of when on heating then starts beeping 1beep 2beeps 3beeps
Some units emit a flashing code. Check your manual to see if the flashes represent a fault code.
Apr 22, 2014 | LG Heating & Cooling
Taken out cmos and ram sticks,switched on and still gives 3beeps,3beeps,1beep
Try to change your RAM . Or if u have more than 1 RAM try to isolate the problem by putting in the 1st stick then try to boot it up. Hope it helps
Nov 22, 2013 | Fujitsu AMILO Pro V2055 PC Notebook
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
Hp pavillion dv6405us error beep code 3 1 4 3 - what does it mean? how do i fix it?
Sounds like a Phoenix BIOS Beep Code, but the 3beeps-1beep-4beeps-3beeps code doesn't come up,
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N908
[ + Beep codes for Phoenix BIOS (for older PCs) ]
1) Has the inside of the computer ever been cleaned?
2) Clean the gold plated contact pins of the Ram Memory modules, ('Stick'), and reinstall.
2a) Use a pencil eraser to clean the gold plated contacts,
Remove ALL power. Remove the AC adapter (Charger) and Battery.
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
If using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band on the pencil contact the gold plated contact pins.
Rub up, and down gently on EACH contact pin. (Both sides) Doesn't take much to clean them. They may not look shiny, and bright when you are done, but I assure you they are clean.
Handle the ram memory module by the BODY. The Body is everywhere on the ram memory module except for the gold plated contact pins.
The Body is coated with a see-through protective plastic.
Use air to remove the eraser dust before reinstalling. If you have a can of compressed air for computers available, use it. If not air pressure from your mouth will be sufficient.
http://www.youtube.com/watch?v=f7sRPDmcE9o
1a) The cooling system uses air to cool the hardware components inside your laptop.
If the cooling system is clogged with 'Gunk', and cannot adequately receive the needed air flow, the Processor and graphics chipset will overheat.
['Gunk' = Dust, dirt, hair, lint, carpet deodorizer, food crumbs, etc ]
The Processor and the graphics chipset (G.P.U.) are the two hardware components that give off the most heat.
Having the laptop dirty inside can cause a serious issue also, and especially on the Pavilion dv6000 series of Notebook PC;
The graphics chipset is mounted to the motherboard with a BGA surface mount. Through constant overheating of the graphics chipset, the solder joints (Connections) may partially melt, then re-solidify when the laptop is turned off. (Cools down)
This cause cold solder joints of the graphics chipset to motherboard, and a poor contact of graphics chipset to motherboard.
The problem with the Pavilion dv2000, dv6000, and dv9000 series of Notebook PC's, is inadequate cooling for the graphics chipset.
1) http://www.youtube.com/watch?v=JEpnqhRYGLw
2) Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
3) The integrated circuit, or chipset for graphics; is the graphics chipset, or G.P.U.,
http://en.wikipedia.org/wiki/GPU
4) Video showing an average BGA (Ball Grid Array) Rework Station at work, and showing the Solder Balls, and Copper Pads of a BGA surface mount,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll down, click on the Red -
Take a few minutes to view the IR 650 demo video
Regards,
joecoolvette
Sep 18, 2012 | HP Pavilion DV6405US 15.4" Notebook PC PC...
Acer 5630G Error 07668 Password!?!?!?!?!?
try all these passwords from what you described it looks like a system disabled password and i'm guessing you have pheonix bios therefore i generated some passwords with the code you provided hopefully it helps and works
Generic Phoenix BIOS: dszqtj HP/Compaq Phoenix BIOS: wmxzjzz FSI Phoenix BIOS (generic): 826167 FSI Phoenix BIOS ('L' model): 8197 FSI Phoenix BIOS ('P' model): 1985 FSI Phoenix BIOS ('S' model): 6321543 FSI Phoenix BIOS ('X' model): 5576
Mar 22, 2011 | Acer Aspire 5000 Notebook
Laptop model acer aspire1660 when i try to enter the bios 3 times pass fail it say sistem disabled [10140] eror i forgot the pass i removed the batery from the main board but dont work pls can anione...
Generic Phoenix BIOS: vrgw HP/Compaq Phoenix BIOS: iyta FSI Phoenix BIOS (generic): 37198 FSI Phoenix BIOS ('L' model): 9941947 FSI Phoenix BIOS ('P' model): 2187164 FSI Phoenix BIOS ('S' model): 41572 FSI Phoenix BIOS ('X' model): 92876
Try all those passwords thanks
Mar 22, 2011 | Computers & Internet
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
When i on my pc normally 3beeps but i only heard 1beep and nothing shows on the screen
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 08, 2010 | Acer Computers & Internet
Toshiba Satellite m55 that will not pass post, 3-4-3 beep code
Sound like your Video Card has gone down i think it cant find the VGA bios
Nov 30, 2009 | Computers & Internet
Need mother board driver:phoenix Phoenix - AwardBIOS v6.00PG
Version EVEREST v2.20.405
Homepage http://www.lavalys.com/
Report Type Quick Report
Computer CRYSTAL_XP
Generator crystal
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2010-03-04
Time 09:01
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Award
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message P4M80-M4 (4M80M609 BF)
System BIOS Date 06/09/07
Video BIOS Date 08/15/06
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
Oct 11, 2008 | Intel Motherboard
Fujitsu Siemens Amilo Pro V2055 V2030 V2035 L1310G FAN Logo
67 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
rdjagger
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
