Question about Samsung Cell Phones
Cannot open the lock - Samsung Cell Phones
    Master:
  • Samsung Master
  • 875 Answers
You mean the network lock on your Samsung phone?I suggest you can approach Theunlockspot.com and specify the model, country, locked network.Based on the availability you can get the unlock code along with free instructions for your Samsung mobile..
Posted on Nov 23, 2013
My lagard lock safe won't open-no battery.
If internal battery is depleted and will not allow lock to open, hold a new9-volt alkaline battery on the contact points (large battery terminal to
large keypad contact, small to small) located on the front of the keypad.
Maintain contact, enter and valid code and turn keypad to open lock.
Lock contains a non-volatile
memory, even with batteries removed the lock will retain
all programming.
NOTE: You must maintain battery contact at all times throughout the
entire procedure.
Mar 15, 2014 | Safe International Digital Electronic Safe...
How to open a deadlocked rear door.
Hi. remove the rear seat and door pad. You can access the lock through a small hole, break the top inner corner of the lock and it will release the dead lock and open the door.
Jan 29, 2014 | 2004 Volkswagen Golf
THE PETROL CUB IS LOCK WHEN CENTRAL LOCKING IS NOT WORKING
there is a locking pin that runs in conjunction with youre door locks. get the doors to unlock open youre gas door and remove locking pin .this will allow youre gas door to open at all times. hope this helps good luck
Dec 02, 2013 | 2008 Ford Ikon 1.6
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
My drivers side rear door will not open from the inside or outside
I had exact problem Santa Fe 2007 2008 lock was stuck in locked position and door would not open from inside or out. All other doors would unlock with auto key remote. Carefully work the inside lock towards the open position as you lock and unlock the door with the remote. As you press unlock try to assist the lock to open. I did this a few times and the lock became free to the open position and all worked perfectly after this.
Feb 02, 2013 | 2007 Hyundai Santa Fe Limited
Drivers door and fuel cap not locking with central locking have to lock door with key also fuel cap does not lock all other doors lock and open with central locking drivers door opens with central locking
Hello Alan,
I would suspect the fuel flap actuator has failed. Open the trunk. In the right rear corner is the access cover. Open it and you'll see some insulation matting near the top. Behind it is a fuse/relay carrier, I believe either fuse 55 or 56 is blown. If so the fuel flap actuator needs replaced. The fuse also controls the central locking system.
Apr 26, 2011 | BMW 318 Cars & Trucks
Hi, Somehow the boot of the car has locked
All locking and unlocking is done through the switch on the drivers door lock. Put the key in the drivers door and lock and unlock several times. See if the boot opens then.
Or make sure you haven't hit the lockout button on the drivers door that stops anyone else from opening their doors. (Including the boot.)
Aug 17, 2009 | 2000 Chrysler Grand Voyager
Lock won't open
Have 5400D Master Lock. Know combination, but it will not open. Can someone help me?
Aug 18, 2007 | Master Lock 5400d: Portable Select Access...
Cell Phones Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
