Question about Fujitsu Siemens Amilo Pro V2055 V2030 V2035 L1310G FAN
3 beeps 3beeps 1beep
3beeps,3beeps,1beep
  • 47 Answers
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
Posted on Nov 24, 2013
Testimonial: "battery is fine,memory reseated-still gives 3beeps 3beep 1beep."
  • why2for Nov 24, 2013
    You will need to call Fujitsu - because of the wide variety of different BIOSes, the beep codes vary.
Air con switches of when on heating then starts beeping 1beep 2beeps 3beeps
Some units emit a flashing code. Check your manual to see if the flashes represent a fault code.
Apr 22, 2014 | LG Heating & Cooling
Taken out cmos and ram sticks,switched on and still gives 3beeps,3beeps,1beep
Try to change your RAM . Or if u have more than 1 RAM try to isolate the problem by putting in the 1st stick then try to boot it up. Hope it helps
Nov 22, 2013 | Fujitsu AMILO Pro V2055 PC Notebook
Phoenix bios
Are you sure this isn't a 4 beat sequence? such as 2-1-2-1?
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
My hard drive doesn't boot up as normal. When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps. Numbers 3 and 4 on the hard drive are...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 29, 2010 | Computers & Internet
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
When i on my pc normally 3beeps but i only heard 1beep and nothing shows on the screen
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Oct 08, 2010 | Acer Computers & Internet
1 beep 5beeps 1beep 1beep
Try remove the ram and clean the part and put it back ,.
Dec 02, 2009 | Intel Server Board SDS2 Motherboard
Toshiba Satellite m55 that will not pass post, 3-4-3 beep code
Sound like your Video Card has gone down i think it cant find the VGA bios
Nov 30, 2009 | Computers & Internet
When start on asus motherboard 1beep+1beep sound total 2 beep sou
The problem is the system memory, get yourself a clean, dry soft paintbrush, remove the power cord from the back of the unit, remove the memory and clean the brass contacts on the memory modules, next clean the memory slots of any dust that may have built up and reseat the memory.
Put the side panel back on and plug in the power cord then power up.
Good luck
Jun 19, 2009 | Intel Motherboard
2 beep sound on restart in asus motherboard
memory problem or graphics problem change them
Jan 14, 2009 | Intel Motherboard
Fujitsu Siemens Amilo Pro V2055 V2030 V2035 L1310G FAN Logo
123 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
rdjagger
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
