Question about FUJIFILM FinePix S200EXR Digital Camera
Command dial is missing on my camera. - FUJIFILM FinePix S200EXR Digital Camera
How to change the shutter speed on my nikon n65 film 35mm slr camera
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
Oct 13, 2012 | Nikon N65 35mm SLR Camera
How do I turn on the Rear Command Dial in my Nikon D80 Digital Camera?
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode.
If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Jun 29, 2011 | Cameras
I have a Nikon D3100 and surprisingly the dial mode does not work properly. I mean when I turn it, at some modes, it shows the selected mode correctly on the display, but not for all
Hello mehran_vafae, is supposed to have put a DX lens.
The mode dial, select in what way is going to take a picture.
You can make combinations according to the mode set in the mode dial, with the Fn key / command dial, command dial / aperture A mode, command dial / shutter speed S mode, Full Auto / + / - compensation sw, etc. ..
Please carefully read the user manual supplied with your camera and if it fails take them to Nikon service.
Regards
Mar 21, 2011 | Nikon Cameras
Front control wheel does not operate shutter speed
Hi,dontgartside, check setup of command dials.
Factory setup = main command dial shutter speed (back command)
,sub command dia ( front command dial aperture selector).
Regards
Feb 26, 2011 | Nikon D2H Set Digital Camera
How can i set aperture and shutter speed at P mode? i scroll the command dial but all that comes in is P and P*
Once you're in the P mode, turning the command dial will change the shutter speed and aperture in opposite directions to maintain the same exposure (within the limits of the camera and the lens). You should see the shutter speed in the viewfinder change.
If you want absolute control of the shutter speed, change to the S mode. The command dial will then allow you to control the shutter speed, and the camera will automatically change the aperture to compensate (again, within the limits of the lens).
Feb 12, 2011 | Nikon D5000 Digital Camera
What is the command dial?
The command dial is the knurled wheel that falls under your right thumb when you hold the camera in shooting position. It's used in conjunction with the buttons on the camera to change settings.
Dec 26, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
How can I change the exposures, or f-stops on the Nikon N75 35mm camera?
That depends on the exposure mode. In the point&shoot modes the camera sets the exposure.
In P you can turn the command dial to change the exposure.
In S you turn the command dial to set the shutter speed, the camera changes the aperture to suit.
In A you turn the command dial to set the aperture, the camera changes the shutter speed to suit.
In M you turn the command dial to set the shutter speed, you hold down the aperture button and turn the command dial to set the aperture.
If you don't have a manual, get one from http://www.butkus.org/chinon/nikon.htm
Oct 16, 2008 | Nikon Cameras
Command Dial not working
Have you solved your D40 problem yet? If not, give more details for further assis.tance
May 03, 2008 | Nikon D40x Digital Camera
Command dial on my s9500 doesn't work. Does anybody has the service manual or knows how much does the repair cost
contact fuji spares department, I am hoping to get mine repaired free as it is a design fault . There is a small plastic shaft from mthe rear of the dial that breaks with normal use .... tel No on www.cameras.co.uk
Mar 01, 2008 | Fuji FinePix S9500 Zoom Digital Camera
Command Dial Malfunction?
I guess ther may be - Fuji Tech Support is the best place to find out. There are so many variables in the makes/models of camera only the makers tech support will tell you unless one of us knows the exact camera.
Jul 03, 2007 | Nikon Coolpix 5700 Digital Camera
FUJIFILM FinePix S200EXR Digital Camera Logo
42 people viewed this question
Top FUJIFILM Cameras Experts
Steve
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
