Question about Electrolux Refrigerators
Electrolux odel ei26ss55gs6 would make ice intermittently,changed water filter,now doesx not make ice,switched wires on water valve and water did come out the water dispenser,is it the valve?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 125 Answers
Have you tried unplugging it and plugging it in again?
Posted on Nov 22, 2013
  • 3422 Answers
SOURCE: ice maker doesn't work. changed filter. light on ice maker door still on.
Just check THIS link out.It will solve your problem.
From my side i believe it is the control board which has to be replaced and it will work again.
Goodluck..
Posted on Apr 05, 2008
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
woodchuck789
  • 4070 Answers
SOURCE: Electrolux will not make ice. the water will dispense
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Posted on Aug 17, 2009
nnesmith
  • 162 Answers
SOURCE: GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Posted on Jan 19, 2010
  • 572 Answers
SOURCE: MY Jenn-Aire bottom freezer, with water dispenser
check water supply hose. if ok the check valve
Posted on Feb 08, 2010
Electrolux ei26ss55gs6,makes ice ,then will not
Might besetting and adjustment problem .lower the temperature in the fridge
Dec 06, 2013 | Electrolux EW23CS65SS Stainless Steel Side...
Good Morning Denise, thank you for allowing me to assist you!
If your ice maker has stopped producing ice completely, please check these tips, in this order:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
Also the water shut-off valve or water-inlet valve, or both, may be faulty and if necessary either parts may need replacing. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it after proper diagnoses.
Best regards!
Nov 22, 2013 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Electrolux Ref. 3yrs old. ice maker will not make ice, water dispencer will work. I have replaced filter.Ice maker goes through the motion but, no water. can you help me?
either your fill tube is clogged or the water valve in the back of the refer has failed. Go to the back of the unit, if my memory is correct the yellow hose is for the ice maker, at the water valve disconnect the 1/4 hose from the valve to the ice maker only, place valve in a bowl, cycle ice maker. If you get water, fill tube is obstructed, if not water the valve has failed and needs to be replaced.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 28, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Electrolux Pure advantage water filter
Open and shut the water valve quickly to verify the water supply, it could be a bad water supply valve. Bench test the filters for flow or obstruction.
Aug 01, 2017 | Electrolux Icon Freezers
Ice maker not making ice
Hello KC Breen - If your ice maker has stopped producing ice completely, please check these, in this order:
1. Your ice maker may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency.
4. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
5. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Should these suggestions prove ineffective, I would recommend contacting an authorized service technician that will be able to assist you in the diagnosis and repair of your ice maker. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area.
Mar 17, 2013 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Jan 10, 2012 | Electrolux Refrigerators
Water will not dispense from electrolux side by side front door refridgerator
I would check the water valve. Many of these refrigerators use a dual cylinder water valve and sometimes one of hose cylinders goes bad. The filter is at the inlet so if its still making ice, that means that the valve is still getting water.
Jan 02, 2010 | Electrolux EI26SS55GS Stainless Steel ...
Aug 17, 2009 | Electrolux EW23CS65SS Stainless Steel Side...
Changing water filter in Frigidaire fridge every 3 months
You should change out the water valve on your refrigerator. The filter shouldn't make any difference on the flow. We have parts and supplies for Electrolux, so call us with your model number and we'll be sure to get the correct water valve out to you right away!
Jul 07, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Refrigerators Logo
80 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
