Question about Zebra TLP 2844-Z Thermal Label Printer
Printing text at the same label in two directions
May I print text in 2 directions in one label? half of the text to be read from top to buttom and half of the text at the same label from bottom to top(rotate at 180 degrees)
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Have you tried unplugging it and plugging it in again?
Posted on Nov 22, 2013
  • 54 Answers
SOURCE: Zebra 170PAX3 not printing the top half of label
If you print a power on test label, see if the print is aligned, id so, use the top of form setttings to get all the print on the label.
As far as a USB, the printer will only take RS232-422,485, and parallel, and you can add the factory Nic card or use an external print server.
Posted on Feb 25, 2009
  • 62 Answers
SOURCE: Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Posted on Nov 17, 2009
  • 35 Answers
SOURCE: zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Posted on Feb 16, 2010
printertech1
  • 96 Answers
SOURCE: I am using a Zebra
Label position may be off. Power on while pressing the cancel key for 10 seconds. This should print a configuration label. Use large label for this. Check the parameters, specifically top position and tear off position. The default is 0. You might also check the main drive belt for stretch or missing teeth. You need a user manual for that printer because there is no lcd panel. It is not user friendly without manual.
Posted on Nov 21, 2010
ozztech
  • 285 Answers
SOURCE: label prints at the buttom
check if seting from LABEL TOP is on 0000, check the driver as well.
Posted on Mar 26, 2011
Not printing properly
Printhead should be cleaned with a 90% alcohol solution, however that should not cause blurry print. I've seen some labeling programs that will blur part of your label after the trial period has expired. I would check to see if this happens on test prints also. Do a test print by holding down the button on power up and letting it go after the first blink.
Jun 09, 2015 | Zebra GK420D Direct Thermal Label Printer
Toshiba TEC B-472 printing only top half of label
Perform hard reset of electronics and also re install the driver.
Sep 17, 2017 | Toshiba TEC Office Equipment & Supplies
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
I am using a Zebra 105SE printer. When I print labels, I can not get the text to start at the top of the label. No matter what I do, the text starts half way down the label.
Nov 11, 2010 | Zebra 105Se Thermal Printer
Label prints at the buttom
Feb 17, 2010 | Zebra Z4Mplus Label Printer
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Aug 12, 2009 | Dymo LabelWriter 330 Thermal Printer
Different label alignment on different printers
Right click on the printer icon and choose properties
Feb 03, 2009 | Kyocera Mita FS 1010 Laser Printer
Dec 08, 2008 | Zebra 170XiIIIPlus Thermal Label Printer
Dymo label 400 turbo.
THERE MUST BE PROBLEM IN THE INK OF THE PRINTER CHANGE THE INK N U WIL NOT FACE IT AGAIN
May 24, 2008 | Dymo LabelWriter 400 Thermal Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
37 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
