Question about Cell Phones
Intex force charging - Cell Phones
Intex spa has power but just makes a loud constant sound. Lights go on. Pump will not flow water. What happened? Was working just fine for 2 months. Is it fixable?
It looks it would be worth fixing, first I would check the power, the plugs and voltage. it has heat so it requires the proper power cords to supply it,
If all checks out I would contact intex, if there is not any warranty, I would search your area for a electric motor repair shop, tell them its a spa pump with a heater,
I would be happy to look at it for you at no charge to see whats it's fault is. I'm in central Florida.. here are the error CODES. best of luck.. Jay
Dec 31, 2014 | Intex Pool & Spa
Can you force a saltwater pump to produce chlorine?
the pump doesn't produce chlorine the salt system does it with a salt system and salt in pool
Jun 07, 2014 | Intex Automatic Salt Water System for ...
Sand filter overheats
your pump shaft must be tight to turn , this could be caused by improper pump off season storage/or normal worn out or your sand charge is getting thru the filter , either one spells disaster for pump
Mar 21, 2014 | INTEX Sand Filter Pump
No suction at the skimmer
water level is too high in pool water level should be half an inch thickness of adults index finger at nail above the white plastic edge of skimmer
Jun 17, 2013 | INTEX Sand Filter Pump
Intex sand filter has low pressure
to low a pressure on a sand filter most often is caused by a improper sand charge inside it
Sep 21, 2012 | INTEX Sand Filter Pump
My intex sand filter will not move water when I put the lever to filter? It will move water when I put the lever to recirc but wont move water with filter...why?
im gonna guess that you stored the filter improperly off season and now the sand charge is hard as cement inside not alowing water to get thru , left alone for a week or so it might loosen up , but the best thing is to dissasemble filter and remove all sand and ck "fingers" inside this is fastest way
i allways use RV antifreeze 30/1 to store any pumps or filters off season , RV type because its nontoxic
Jun 30, 2012 | INTEX Sand Filter Pump
Forget security code
You can get the master reset code at here
Theunlockarena.com and reset from security lock.
Sep 09, 2011 | Cell Phones
Which is better the Intex Salt Water Chlorinator (stand alone)or Combo Unit with Filter Pump?
it depends on your size pool anything over 16 feet should have at least a 4000gph pump. The all in one unit only has a 2000gph and can not be up graded.
At least with the stand alone unit you can upgrade to the intex 4000gph and filter anything.
if you look on line you can pick up the stand alone salt and the 4000gph unit for almost the same price as the all in one
Do not buy it from intex they charge to much.
Even on e-bay they are about 149 or so with free shipping the all in one is over 300
hope this helps
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Where i search intex webcam drivers
as soon as possible to solve the problem of drive
Aug 07, 2008 | LG LPC-UC35 Webcam
Cell Phones Logo
191 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
