The house I am in has a Lennox cb19-51-1p unit. at 3 in the morning it stopped all heat output but kept blowing. now all it is doing is beeping intermittently. I know I will need to have someone out as the temps are getting down to 11 at night, but as this is not my house I am a little weary to spend hundreds on repair. any suggestions? thanks
  • Scott Thornton Dec 06, 2013
    have you checked the indoor unit filters, this can cause the indoor coil to get to hot if they're not allowing enough air over the coil
    also turn off the main isolater for 1minute & reset after cleaning filter.
    Top Expert:
  • Heating & Co... Master
  • 12,957 Answers
The compressor is not running but the fan is. Could be the thermostat - it has a circuit that turns on the compressor in times of "need."
U can check for proper compressor operation by removing cover of unit and locating the compactor relay - with a wooden stick push it closed and see if the compressor kicks on. If it does then the control circuits that issue the 24 volts to power the relay are not working. Or if the 24 volt power supply is non existent the relay will not close and connect the compressor the power lines.
Posted on Nov 23, 2013
  • 619 Answers
SOURCE: Lennox heat pump shuts down every 2/3 days
Hi , you may use amphere meter to detect whats goin on to the compressor and component.
Clamp one compressor wire if register exceed the laber amphere of motor motor are stuck or burn/
If not register the clamp meter check the thermal control might burn or lost contact.
Posted on Jan 12, 2008
  • 306 Answers
SOURCE: Lennox Elite Model # CB30M-65-4P
The copper the big line should have a insulating foam wrapped around it called rubetex which eliminates any rubbing. They should never be that close also. Now is this unit a heat pump?
Posted on Nov 24, 2008
Accurate Joe
  • 61 Answers
SOURCE: Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Posted on Nov 29, 2008
  • 85 Answers
SOURCE: Heat Pump Stops Working only in the Early Morning
I recommend getting electric back up heat to fix your problem. Like the other gentleman said, defrost is having to kick on too much. It's doing the best it can givin the conditions outside. If you don't have enough power supply for electric back up heat, then a gas furnace or propane furnace will work also, depending on your needs. Heat Pumps are a like a full time fan, they are designed to heat your home at a steady rate unlike forced gas units that turn on extremely high temps and then shut off... Ensure your charge is correct, givin your tempatures the unit sounds to be working correctly, however a second opinion is always a good piece of mind before you spend money on emergency heat.. Hope that helps..
Posted on Dec 02, 2008
  • 17 Answers
SOURCE: 3 amp fuse blows after three hours on Goodman 4 ton 16 seer pump
I would suspect you have a problem in the defrost circuit of your heat pump. there are a couple of things you can try. first just run the system on emergency heat and see what happens. you could have a defrost board that is shorting when it kicks into defrost. it sends a signal back to the furnace so it will come on during defrost. if you do not blow a fuse as long as you are running in emergency heat, i would suspect the defrost control board. also you could have a dead short in the wire that runs from the "w" terminal on furnace control board, out to the heat pump. keep in mind that any of the wires could be the cause and i am just tying to give you the most common things. your furnace will still run if you unhook all the low voltage wiring out at the heat pump. if you do this and stop blowing fuses. you know it is something on that wiring. goodl luck.
Posted on Jan 27, 2009
I submitted a ? Earlier in reference to the igniter on my Coleman central unit w model PAC036H1021A.. My unit stopped blowing heat and was blowing cold air only in the house. It stopped last night and I...
It sounds like you may have electric heat. With that being the case and your description of a burning smell indicates an electrical problem. Since you did get it to start heating it sounds like a possible heat relay problem. I have also found burned connections and I was able to repair them and get the heat strips working again. If you know an air-conditioning and heating technician or electrician you should try to get assistance. The voltage in these units is dangerous and one mistake could only make things worse.
Feb 13, 2015 | Coleman Heating & Cooling
Why does our Lennox AC Air Handler, Model CBX26UH-060 makes a beeping sound when it starts up?
Dear Friend,
Normally all Lennox handler beeps right after turning on and off, but if beeps all the time it might be that there is an error with the handler or it beeps because it was program to beep when going on and off. Please refer to your user manual for any beeping error.
Good Luck!
Sep 20, 2014 | Heating & Cooling
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
Apr 19, 2017 | Heating & Cooling
GE Zoneline 1000 - heat stopped working this morning, A/C is working fine, fan is working fine, buzz sound when heat is turned on as normal, thermostat seems fine as room is still warm, can turn thermostat...
Sorry to read about your problem, I hope this helps you out.
Sounds like you may a defective, reverse heat pump switch. If you were in Denver,Co I would be glad to work on it for you. They are no different than large units to work on.
and no, you cant work on the unit.....takes special tools
Just keep calling around for a person who will work on the unit..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | GE Zoneline AZ25E12D3B Air Conditioner
I have a Lennox CB29M Air Handler with an electric heater, which is used to heat the lower two rooms of my house. The handler unit is located in a mud room right behind the back patio. I'd like to get an...
Any of these Lennox dealers can help you choose a compatible HS29 or HP 29 condenser and evaporator coil to match your system.
http://www.lennox.com/locate/default.asp
Jul 06, 2010 | Heating & Cooling
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
Jun 09, 2017 | Heating & Cooling
Lennox Fan will not come on when set to ''auto'' position.
Expensive is relative, service calls are never free. But if you have an idea what the problem is, you are armed against an unethical service company. Now to what you describe, could be a couple things, first let me explain the difference in fan speeds. Furnaces that both heat and cool have multi-speed blower motors. High speed is for cooling and lower speeds are for heating. The fan switch at the T-Stat turns on the high speed fan relay. The lower speed fan is turned on by either a temperature activated switch (silver box mounted on front on furnace above burners) or a time delay relay which is solid state. That being said, your problem could be a defective fan switch or one of your blower motor windings has gone bad. Most motors have 3 or 4 speeds and a technician could just change speeds and all would be good. A fan/limit switch is not so expensive that you would replace the unit. Bottom line, unless your really handy, a heating company is in your future. Good luck and please rate my answer if it was helpful to you.
Dec 31, 2009 | Superior Lennox Blower Thermal Sensor -...
Lennox G40UH(x) series - Air not coming on
electrical connections @ the furnace may the thermostat .Tom
Jun 18, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
