Question about Honeywell S8610U3009 Universal Intermittent Pilot Control Module
Keep replace control honeytwell s8610u3009
Hav install three control that seem to run ok when I am there then aday or to later goes out on 6 green flashes on Honeywell control s8610u3009u
    New Friend:
  • 24 Answers
Bad capacitor
Posted on Jan 01, 2014
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
Keep replacing control
Check to see if anything on the low voltage circuit is stealing voltage ie gas valve...make sure you have the proper low voltage to the ignition module (check the transformer)
Nov 22, 2013 | Honeywell S8610U3009 Universal...
A O Smith GPSH 40 200 wont stay lit. Code lights are Green (labeled warm) + A + B
Copy following link for Intellivent service manuals, and error codes:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Wiring error
Check outlet polarity using circuit analyzer.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#polarity
Check that outlet is fully grounded.
Check that ground wire has continuity to manifold tube (largest tube connected to bottom of gas control valve)
Mar 19, 2013 | Water Heaters
Is the American Standard G50T 2-3-6 a good water heater? I have trying to find stuff about them on Google but I keep getting results for american water heaters not american Standard and the reviews are not...
Generally, they are a your normal low end hot water heater. I have seen American Standard units last up to 20 years (like mine) with not problems, and I have seen them not last three years before the tank ruptured.
We have more calls on the Rheem and Brandford Whites than American Standards as far an minor problems.
Pros: Cheap; reasonably reliable; parts readily available.
Cons: Not energy efficient; tank quality - flexible.
When mine goes would I replace it with another American Standard? No, I would install the Bosch tankless water heater.
Jun 24, 2011 | American Standard AMERICAN STD 100 Prop...
Water leaking observed from the bottom of the tank. What's the problem? Should I replace the old 21V40-2 unit? if so, what kind of tank is ok to replace the present unit? What's the price and installation...
If water heater is leaking, then open following 2 links to avoid tank rupture and troubleshoot leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
http://waterheatertimer.org/Water-heater-is-leaking.html
Open following link if you want to install your own gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
To have gas water heater installed, can run $2-300 for installation plus cost of heater.
40 gallon natural gas water heater at Lowes starts at $300+, and tanks with longer warranty cost more and last longer.
If you maintain the tank: keep chemicals out of same room as water heater, attach bare copper ground wire between hot and cold pipes, flush tank each 6 months, clean burner each year as shown in manual, read the manual entirely for specific information about your model, and inspect/replace anode rod every 2-3 years then basic 6-year tank can last much longer.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Apr 07, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Flammable sensor is lit and won't go off. I replaced the sensor how do i reset the controller?
Certain water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts. I'm not sure what control your unit has, but on a White Rodgers here's how it goes.
White Rodgers Intelli-Vent PowerVent Control Equipped Models
  1. Step 1 Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
  2. Step 2 Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful
Oct 15, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Atwood 10 gallon H2O heater- replaced thermal couple and electrode spark and sensor but heater comes on with switch, heats water for 10 to 15 mins then burner goes out. Can hear a couple of switching...
I'd check that ECO and thermostat discs are making contact properly with tank.Just peel back foam cover on outside of tank that has ECO and THERM marked on it. If they are installed correctly, replace them.
Aug 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I hav an attwood g6a-7, replaced the thermal-coupler and stil the pilot light will go out as soon as i release the knob. been running it for weeks, shutin it down on weekends when i go home, then...
Try removing the thermocouple where it attaches to gas control, and spray a little WD-40 in the hole, then spin a rolled up small piece of steel wool in the hole as well, then blow it out with compressed air if you can. Then reconnect thermocouple. Make sure thermocouple tip is getting good flame under it, and if that doesn't cure it, then it's time to replace gas control.
Jun 23, 2010 | RTO Atwood Water Heater - 6 Gal LP
Installing new flomaster xp2 pump. what color wies
Are you asking about the cord from themotor to the control? If so It should either be Green Black and white or all those plus a red. The green is the ground and it goes on the green screw. White goes to the common or line(1) post, and usually red is Hi and Blk low for the speeds. If it is a single speed only no red and black will go to the other line(2).
If this does not answer your question please post a comment with what wires and where you are dealing with.
Dec 18, 2009 | Water Heaters
I have a Rheem Criterion II Gas furnace. It is not igniting.  When I switch the thermostat to "heat" - the furnace doesn't not start.  There are 2 green lights - one is one and the other is blinking.  The...
Roscoe007 shouldnt speak unless he knows what he is talking about, as a heater installer i am telling you the ignitor needs to be replaced, the very fact that the ignitor does light for about 30 sec than goes out rules out any issue with the themostat, replace the ignitor!
Dec 13, 2008 | Water Heaters
Honeywell S8610U3009 Universal Intermittent Pilot Control Module Logo
49 people viewed this question
Top Honeywell Water Heaters Experts
paulcarew
Lawrence Oravetz
Steve
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
