Question about Garden
460 Rancher sparks coming from excust - Garden
    Sergeant:
  • Garden Expert
  • 417 Answers
This is a pro model saw used by professionals to earn a living and is not intended for homeowners. Spark arrestor screens are installed in the mufflers of virtually all 2-cycle equipment to stop sparks from flying out of the muffler and catching the forest on fire. They do a great job of this, but are prone to carbon buildup from a collection of these hot embers clumping together and blocking the port so a lack of power or even a no-start situation is observed. You can remove these, but it is not recommended as you will possibly light the forest on fire. You can remove the screen and hold it with needle nose pliers while you cook it to red hot with a torch and the carbon will simply fall off. Immediately dip the cherry red screen in a small cup of motor oil to temper it, then clean it once cool with wd-40 and re-install it. It sounds however that someone removed it completely.
Posted on Nov 23, 2013
4 Suggested Answers
  • 12 Answers
SOURCE: I have a new hasky 460 rancher stalls when given
If it stumbles at full throttle, the fast (high) idle screw is set too rich. Using your owner's manual, locate the high idle adjustment and back it off in very very small increments. Do this until the saw will run wide open without stumbling.
Posted on Jun 13, 2010
  • 2239 Answers
SOURCE: husquvarna 460 rancher 20" bar all new including
The normal reason for a saw to cut to the left, or right is because the cutters have been sharpened more on side than the other, they are now longer on one side, this then sends the cut off to that side. Measure the cutter lenghts, take the correct file and shorten the longer cutters
Posted on Mar 06, 2011
Testimonial: "Thank you it was a new chain sharpened once"
  • 95 Answers
SOURCE: New 460 rancher 20" bar and chain cuts at an
It sounds like your chain is just dull.Or might not be sharpened right.This usually happens when the chain is getting dull.
Posted on Mar 09, 2011
Testimonial: "I think you may be correct, although the bar and chain are new it appears that one side of the chain has been sharpened at adifferent angle. Regards "
Wont start, spews fuel out of combustion chamber, spark plug wet
sounds like the diaphram in the carb ..you will have to take carb apart clean and rebuild or just purchase new carb, I believe there are not to expensive, about 60 bucks..hope this helps..good luck
Sep 06, 2015 | Husqvarna 460 Rancher 24" 60cc Gas Powered...
High and low setting for hasqvanna 460
Husqvarna 460 Rancher Manuals
www.manualslib.com > Brands > Husqvarna Manuals > Chainsaw
Manuals and User Guides for Husqvarna 460 Rancher. We have 3 Husqvarna 460 Rancher manuals available for free PDF download: Operator's Manual ...
Jul 23, 2015 | Husqvarna 20" 60cc Rancher Chain Saw 460
Replace sprocket on rancher 460
The factory do not offer a rim sprocket for the 455/460, they are classed as semi pro saws and as such get a spur sprocket, there may be an Oregon after market one available.
Dec 29, 2012 | Husqvarna 20" 60cc Rancher Chain Saw 460
Plug settings for husqvarna 460 rancher
If you're referring to gap settings, whatever the gap is when you get the new plug from the manufacturer will be sufficient. You can purchase replacement spark plugs from PartsBuggy.com.
Nov 26, 2011 | Husqvarna Garden
Mar 09, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Husquvarna 460 rancher 20" bar all new including
Mar 06, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
The powersaw did not start because no ignition power despite the stop switch is open
Check "continuity" between spark plug and lead. I had this problem once and found that the wire from the coil was not making contact to the plug.
Sep 27, 2010 | Husqvarna 20" 60cc Rancher Chain Saw 460
Jun 06, 2010 | Husqvarna 20" 60cc Rancher Chain Saw 460
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
