Question about Mitsubishi Office Equipment & Supplies
MITSUBISH TERMAL PRINTER WHERE ARE YOU
I WHANT THR THERMAL INK
Locked ibm 3476 terminal
test the cabel wich go to the termal head and blow unit out.
Oct 20, 2011 | Zebra 105Se Thermal Printer
Good Morning, Z4M plus TM how to change printer cartridge?
Here is a link to the manual that "should" answer any questions you have about the printer. I've had to reference it SEVERAL times!!
http://www.servopack.de/support/zebra/Z4Mplus_Z6Mplus.pdf
Hope this gives you what you need!
Mar 15, 2011 | Zebra Z4Mplus Label Printer
Ribbon in Printer Idle error
xgech if using ribbon, change the seting to Direct termal, if not, change to Termal transfer. save,(press 2x the enter button) restart the printer
Nov 05, 2010 | Zebra S4M Thermal Label Printer
When sending a multiple pages fax....after every page, it says line error. Freaking annoying.
Check Your Drum on the back cover You may have some paper are stuck in to il .... and make sure your termal paper are on the right side check cafully the way you install your Termal paper
Sep 22, 2010 | Sharp UX-P115 Plain Paper Thermal transfer...
Zebra lp 2844 prints a blank test page
possible was reset to factory defult and the darkness is to low, press the button until flash 5 times and let run untill see the dark print. then press the buton again. Try to print again (flash 1x)
outher possibility is the ribbon in on other way.
other possibility is the labels need to use ribbon (Thermal Transfer), and the printer is run out from ribbon.(run as Direct Termal.
Aug 17, 2010 | Zebra LP 2844-Z Thermal Label Printer
Zebra s4m is printing blank pages
turn printer off, press pause buton, tur on, wait 5 secunds and relese the button. He goin to print the test label, Pause. check Darkness seting, ajust if necessery. don't forget to save. To go out from the test, turn printer off and on again.
the ribbon is on the correct way?
The labels are Termal Transfer and you don't have ribbon in the printer.
Jul 02, 2010 | Zebra S4M Thermal Label Printer
Installing ink catridges in ux-41 model
It is a termal paper fax.doesn`t need any ink or etc.use only termall paper.
May 29, 2010 | Sharp UX 510 Plain Paper Thermal transfer...
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
