Question about Dell Computers & Internet
How can i work my dvd it doesn't work on my computer
How can i work my it doesn't work on my computer it say insert a disc
  • 20 Answers
If one DVD does not work, try another failing that , try a cd ..if none work..your laser on DVD is worn/damaged and needs replacing...replace with a new DVD/RW is your best option ..not expensive
Posted on Nov 22, 2013
Dvd player will play store bought DVD's but will reject other dvd's saying unknown disc when inserted
some older models wont recognize burnt DVD's
maybe Netflix discs have a macro on that doesn't allow your player to play them.
Sep 06, 2012 | Zenith XBV243 DVD Player/VCR
E disc it doesn't rI have a gpx DVD player D200B and when I insert thecordnize it. Says
see the next remedies:God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours
Jul 21, 2012 | GPX Televison & Video
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
I have just started using cyberlink products here is my problem. I have used the copy to disc and it copies and all, but when I get ready to play it on my DVD it comes across as unknown disc, not playing...
This could be because the session on the disc is not closed. Computers and many of today’s recorders as well, allows you to keep the session open on a disc in order to be able to continue adding more information on CD-R or DVD-R discs, but leaving it open doesn’t allow you to play it on just any other player.
Insert the DVD into your computer then right click the drive and select "Close Session" ( if the option is available, then test it again.
Mar 28, 2010 | Computers & Internet
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD. I...
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
Aug 15, 2009 | Samsung DVD-R155
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
Computers & Internet Logo
24 people viewed this question
Alun Cox
